Anyone have a secret stock of Mugen 26mm rear swaybars????
Old Oct 8, 2004 | 11:44 AM
Chris93Si's Avatar
Default Anyone have a secret stock of Mugen 26mm rear swaybars????
Well I guess to me for waiting so long to buy one because now they're discontinued and King says no stock left in the US or Japan
Anyone have one lying around or know of anyone who may by some slim chance still have them in stock? If I'm not able to find the 26mm bar I'll probably just go for the JDM bar, just can't justify paying $400 for the Mugen 24mm bar.
Thanks in advance, I'm keeping my fingers crossed
Old Oct 8, 2004 | 12:18 PM
Chris L's Avatar
Default Re: Anyone have a secret stock of Mugen 26mm rear swaybars???? (Chris93Si)
IPS Racing has them listed on their site. Don't know if they're in stock or not though.
Old Oct 8, 2004 | 12:39 PM
ebelp's Avatar
Default Re: Anyone have a secret stock of Mugen 26mm rear swaybars???? (Chris L)
Does anyone here have the 26mm bar? I'd like to hear what they think of it. Although that's a lot thicker, I can't imagine the rear end of the ITR getting that much stiffer.
Old Oct 8, 2004 | 12:42 PM
Doctor CorteZ's Avatar
I must be the only one that thinks that bar is a complete waste of money.
why not get a properly designed rear bar ?
and yes , the rear of the ITR can be much stiffer.
Old Oct 8, 2004 | 12:50 PM
Dr. EKology's Avatar
Default Re: Anyone have a secret stock of Mugen 26mm rear swaybars???? (Doctor CorteZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">I must be the only one that thinks that bar is a complete waste of money.
http://www.sanerperffab.com
Chris93Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">why not get a properly designed rear bar ? </TD></TR></TABLE>
Care to fill us in??? I'm interested in any and all options
ebelp: Kepani has the 26mm rear bar and absolutely loves it, maybe he'll chime in on its effectiveness
Old Oct 8, 2004 | 12:51 PM
.RJ's Avatar
.RJ
Default Re: Anyone have a secret stock of Mugen 26mm rear swaybars???? (EKology)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKology &raquo;</TD></TR><TR><TD CLASS="quote">http://www.sanerperffab.com </TD></TR></TABLE>
I have a ground-control 1" (25.5mm) rear bar that's going in before the next event
Old Oct 8, 2004 | 12:55 PM
exactly.
Old Oct 8, 2004 | 01:02 PM
Default Re: Anyone have a secret stock of Mugen 26mm rear swaybars???? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
I have a ground-control 1" (25.5mm) rear bar that's going in before the next event</TD></TR></TABLE>
Just curious, where exactly are the mounting points for the Ground-Control bar?
Old Oct 8, 2004 | 01:04 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKology &raquo;</TD></TR><TR><TD CLASS="quote">Just curious, where exactly are the mounting points for the Ground-Control bar?</TD></TR></TABLE>
Same as stock... Where else would it mount?
Old Oct 8, 2004 | 01:06 PM
Same as stock... Where else would it mount?</TD></TR></TABLE>
I remember reading about certain bars being better when they mount to the shock mounts in the rear? I may be totally off though.
Old Oct 8, 2004 | 01:08 PM
I remember reading about certain bars being better when they mount to the shock mounts in the rear? I may be totally off though.</TD></TR></TABLE>
the farther outboard it mounts the better it works.
ITR/OEM mount points are terrible IMO.
Old Oct 8, 2004 | 01:11 PM
ITR/OEM mount points are terrible IMO.</TD></TR></TABLE>
It must have been one of your posts where I got that notion from.
Old Oct 8, 2004 | 01:12 PM
sounds about right.
Old Oct 8, 2004 | 04:01 PM
Dirt's Avatar
Waste of money? wtfh Not if you want rotation like whoa for autocross.
Dbl A -whose rEEr baR thickness is 23mm.
Old Oct 8, 2004 | 04:16 PM
.RJ's Avatar
.RJ
Default Re: Anyone have a secret stock of Mugen 26mm rear swaybars???? (BrewCityR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrewCityR &raquo;</TD></TR><TR><TD CLASS="quote">Waste of money? wtfh Not if you want rotation like whoa for autocross.
Dbl A -whose rEEr baR thickness is 23mm. </TD></TR></TABLE>
j00 r33r baR is t00 small, donkey!
i rode wif kris n (that scamma!) in j00 kaa, it undorst33rd and n33dZ m0 rEEr BaR!!!
Old Oct 8, 2004 | 07:04 PM
kepani's Avatar
Default Re: Anyone have a secret stock of Mugen 26mm rear swaybars???? (ebelp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone here have the 26mm bar? I'd like to hear what they think of it.</TD></TR></TABLE>
i know a lot of others have the 26mm mugen rear sway. hopefully they too can post here. and there sure are a lot of threads [archived] that you can refer to. in a nutshell - i love it. i drove around with the b6 zeals (10kg/mm, 6kg/mm) with the stock 22mm bar for about a month before installing it. the suspension by itself was a huge improvement. but after adding the rear bar, the turn in on the car was much sharper and "cleaner".
the way i understand it, the front and rear sway bars are ineffective ways of totally revamping your suspension. they merely tune the front and rear. the bulk of the suspension improvement come from the springs and dampers. so if you're expecting a world of a difference, you'll be disappointed. if you're looking for less lean in the rear and sharper turn-in, you'll be really impressed.
kepani-who knows chris will love it...if it can ever be found.
heel_touge
Jan 29, 2006 02:22 PM
WarrenB
Jan 27, 2004 03:20 PM
Flux
Aug 11, 2003 04:19 PM
ITR#132
Sep 1, 2002 06:30 AM
WayneGro
May 3, 2002 11:49 PM
