How Do You Install Stock GSR Front Lower Control Arms??? Anyone know how???
How Do You Install Stock GSR Front Lower Control Arms??? Anyone know how??? i searched but of course a question like this came up with nothing....i need help ASAP Please!!! going on a 95 Integra GSR
yea but no replies there i figured it doesnt matter since there both integras and the type r forum gets better replies than the integra forum..thats all
take off wheel
remove lower control arm..
place newer control arm on..
replace wheel..
i'm not sure where the problem is here..?
replace wheel..
its i little more complicated, you need a balljoint fork to seperate the lca from the knuckle.
you cant just take out the straight arm that the shock fork connects to, you need to remove the 19mm rear nut (#25 in the pic) by the swaybar mount on the subframe in order to pull out the whole lower wishbone, actually you may need to drop that whole bushing but i cant rember off the top of my head..
and if you have a sway bar which you should you unbolt that i think its a 12 or 14mm... then you go under the car and follow the ends of the LCA and start to unbolt it i think its 1 17 and 2 19s or something. then it will come off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got Milk »</TD></TR><TR><TD CLASS="quote">How Do You Install Stock GSR Front Lower Control Arms??? Anyone know how??? i searched but of course a question like this came up with nothing....i need help ASAP Please!!! going on a 95 Integra GSR</TD></TR></TABLE>
Have you looked at it yet or just posted the question? You'd be done by now....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 »</TD></TR><TR><TD CLASS="quote">Have you looked at it yet or just posted the question? You'd be done by now....
Do'h !
</TD></TR></TABLE>Do'h !
Got Milk
Oct 8, 2004 01:31 PM
