My Big FS Thread
If the price/trade is right, I will deliever to cali/west coast...I hate shipping
***New stufff***
JDM SIR1 Air Intake system....4 pieces, even the ram air type...good for all the jdm freaks..........................make offers
Complete B18A1 head, no dizzy or mainfolds, comes with Valve cover.......150
B18A1 Flywheel.......................................... ..........40
B18A1 Sensors........................................... .........varies
92 Civic Radiator.......................................... .......20
92 Civic Fan............................................... .........20
Parting Out 89 Acura integra.....
Windows........................................... ..................20 each
Front or Hatch glass............................................. 35 each
Rear struts............................................ ..............15 each
Interior parts/panels............................................ varies
Front Hubs 4 b swap.............................................9 0 for both
Doors............................................. ....................30 each
Side Mirrors........................................... ..............15 each
Stock steering wheel............................................1 5
Dash.............................................. .....................15
Hatch............................................. .....................30
Rear Bumper............................................ ...........20
Tailights...slight crack, no moisture i think...............10 each
Stock exhaust and muffler.....................................30
Radiator.......................................... .....................20
2 fans.............................................. ....................15 each
Struts............................................ ......................10 each
Wiring Harness........................................... ..........20
Brake Booster........................................... ............15
Sunroof........................................... ......................40
D16A1......everything is there...tranny, axles, manifolds, sensors, bad dizzy though....compression check it, and get it out of here....150 if you pull it....250 otherwise Or will part out
Or wheel away the whole damn car for 200....has a bit of front end damage and needs a bit of other ****.....just use it for parts, or try to make some money for yourself......250 If I need to tow it anywhere in vegas
2 relatively new rotors and calipers for older civic/crx, but will work perfectly with any 4*100 to get by, + lifetime warantee.....Calipers and rotors 15 bucks each
B16 SIR1 block needs resleeve............................30
93 Intake Manifold and TB, all sensors minus iacv....40
93 VX Clutch (low life) + press plate.....................15
93 VX Flywheel.......................................... .........30
(95) GSR Cams.............................................. ....100
B16 SIR2 Intake Manifold.....................................50
B16 SIR2 Throttle Body.......................................50
B16 SIR1 TPS............................................... ......40
B16 SIR2 TPS............................................... .......40
B16 SIR2 IACV.............................................. ......40
B16 SIR2 Fuel Rail.............................................. ..25
B16 SIR1 Cams.............................................. ......50
B16 SIR1 Valve Springs........................................30
B16 SIR1 Retainers......................................... .....30
B16 SIR1 Throttle Body.........................................30
B16 SIR1 Pistons........................................... ........offer
B16 SIR1 Rods.............................................. ........offer
B16 SIR2 Clutch/Pressure plate (lil Life on clutch).......20
B16 SIR2 Flywheel.......................................... ........40
B16 SIR1 Lost motion assembly................................40
B16 SIR1 Oil Pans.............................................. .....25
B16 SIR1 Crankshafts....................................... .......30
B16 SIR1 Pulleys........................................... ..........varies
B16 SIR1 Crank pulley............................................ .15
B16 SIR1 Sensors........................................... .........varies
B16 SIR1 Spouts and hose housings...........................10
B16 SIR1 Oil pickup............................................ .......10
1 D series shift linkage........................................... ...25
1 D series shifter........................................... .............15
90-93 integra crossmember and arms.........................35
Brand new 86-89 Integra hub bearing..never used.......40
86-89 Integra spindle....the part that has the wheel studs.....10
D16Y8 Side Mount............................................. ..........10
Universal OEM replacement Catalytic converter 2in diameter...about 20k on it....20
D series Alternator, Carbon pickup may be dirty.............15
B series O2 sensor...with plug...................................10
ALL OBO...many more ****, cuz I know I forgot a lot of ****...just ask
TRADES WELCOME!!!!
<FONT COLOR="purple">AEM Cam gears SOLD
B16 SIR2 Injectors SOLD
1 B16 valve cover SOLD
1 SIR1 B16A Knock Sensors SOLD
1 D series shift linkage SOLD
D16Y8 short.....STR block guard...........SOLD
93 Vtec VX engine and tranny only 78K..............SOLD
B16 SIR1 Intake Manifold...................SOLD
ECU.........................................SOLD
Clean Tenzo type R...................SOLD
Nology wires red...need slight repair on end goin into distributor
Nology Wires Red...................SOLD
17" Konig Monsoons......................SOLD
B16 SIR2 block complete, willing to part out...................SOLD
B16 SIR1 IACV.............................................. ......SOLD
B16 SIR2 Vtec Solenoid........................................SO LD
B16 SIR1 Cam Cap set...........................................SOLD
Brand New Air Filter, never used.............................SOLD
Intake Tube.............................................. ................SOLD
93 exhaust header,good for minime turbo.................SOLD
93 Catylitic converter......................................... .SOLD
4 15" Steelies w/tires..pretty much all new tires......SOLD</FONT>
PM me, AIM me at: C8V6C, or email at C8V6C@yahoo.com
Thanks
***New stufff***
TRADES WELCOME!!!!
Thanks
Championship
Jul 21, 2010 10:01 PM
CTR_EK9
44
Aug 20, 2003 07:35 AM
