Spot free welding?
Old Oct 8, 2004 | 06:16 AM
Aquafina's Avatar
Default Spot free welding?
I'm building a set of picture frames for some ITR brochures I have.
It is a wood frame with aluminum on top of it. I'm securing the aluminum to the wood using threaded rod with nuts. The rod goes through the wood and the nut is on the backside. Could the rod be welded to the aluminum (90* angle) without the aluminum getting discolored on the other side (face side).
TIA, I'm at school right now and can't call around here until tomorrow.
Old Oct 8, 2004 | 06:40 AM
S9i1R's Avatar
Default Re: Spot free welding? (Aquafina)
no, the Al melts @ a lower temp than the bolt does. Just use Epoxy, Liquid Nails or super glue. Liquid Nails is less brittle than the super glue and epoxy.
forsakenriceboy86
Dec 7, 2009 12:05 PM
LOC714
Nov 14, 2009 11:30 PM
PINKS
Apr 19, 2006 08:16 AM
RCautoworks
Jun 28, 2004 07:10 AM
methred_92
Aug 17, 2003 05:49 AM
