Which would be easier to install
The B18 LS motor or the B20B from a CR-V? Im trying to drop either of these into a 1990 Honda CRX HF. Also, if any, what mount kits should I use? I hear that dropping a motor OTHER than a D-series requires either serious under-the-hood construction or a really good mounting kit. Helpful information would be....helpful.
There are lots of mount kits for you to choose from. Place Racing and Hasport both have good mounts. Both the B18B and the B20B will require pretty much the same amount of work. Depending on what year you get, you will have to convert from obd0 to obd1, or obd2. Since you already have an HF I believe you should be set for mpfi, so you wont have to rewire dpi. You will also need a new or modified shift linkage, axles, and maybe an ecu. Go to http://www.hasport.com they have a good swap guide there.
-Lor
-Lor
suprakhmer96
Apr 19, 2005 06:04 AM
