manual transmission fluid questions
Old Dec 14, 2001 | 07:16 PM
LshatchTurbo's Avatar
New User
Default manual transmission fluid questions
Could someone tell me what is the difference between manual tranny fluid and auto tranny fluid? 95 LS tranny has no fluid in it and I went to a few auto part stores and didnt see anything around? Someone help out here
Old Dec 14, 2001 | 08:05 PM
Red Civic T's Avatar
New User
Default Re: manual transmission fluid questions (Zynentech)
Manual or auto? If manual, can use Honda MTF which is good bang for the buck. For autos can use Castrol off the shelf (or whatever brand)...
Old Dec 14, 2001 | 08:12 PM
civicturbo's Avatar
Manual trans takes gear oil which looks a lot like your engine oil except it's much thicker and smells bad.
Trans fluid is a red colored lubricand that is used for a/t and some p/s systems.
Dexron III is used for most cars and Mercon is only for Fords.
If you have a/t use Dexron III.
If you have 5spd trans use 80w or 90w gear oil.
I hope this answers your question!
Old Dec 14, 2001 | 08:54 PM
New User
Default Re: manual transmission fluid questions (civicturbo)
Yes, this is for a manual LS tranny.
Old Dec 14, 2001 | 10:25 PM
Mista Bone's Avatar
D Tranny Guru
Honda MTL or 10w30 for manual trannys
Old Dec 14, 2001 | 10:55 PM
New User
Default Re: manual transmission fluid questions (Mista Bone)
10w30, as in normal motor oil? Are there different types of MTF that are used for different trannys? Says my ls tranny compared to a gsr?
Old Dec 15, 2001 | 12:02 AM
Mista Bone's Avatar
D Tranny Guru
10w30 is motor oil or Honda MTL, I go with the Honda MTL myself.
Old Dec 15, 2001 | 08:45 AM
civicturbo's Avatar
I wouldn't put 10w-30 motor oil in it. That's not a gear oil.
Old Dec 15, 2001 | 09:34 AM
976's Avatar
976
New User
I enjoy redline fluid myself. Can't go wrong w/ honda fluid though...
Old Dec 15, 2001 | 03:34 PM
Gasoline Fumes's Avatar
Gear oil is too thick for Hondas. My owner's manual recommends motor oil.
airikkCRX
Jul 2, 2010 11:49 PM
Kaliona
38
Aug 3, 2009 05:53 PM
spray_bombed
Feb 12, 2007 06:11 PM
Alibi86
Sep 9, 2005 06:02 AM
Speed_Ricer99
14
Feb 20, 2002 08:34 PM
