CTR cams
I have a GSR, do i need to upgrade the valvetrain for reliability? When i get these in and tuned i will be reving like everyday. Also is the stock ecu good or should i get something else. I have a VAFC, is that good enough?
you should upgrade the valve train, at least the intake springs to R springs. If you want to rev to 8400 your doing to need a ECU or chip you existing one. Vafc is good, you will need that to adjust the new vtec crossover and to fine tune the fuel. Get cam gears and maybe a FPR while your at it.
