Stock B Pipe - Are LS/GSR interchangeable?
b pipe? never heard that name before
but if its on the exhaust system, which im assuming, then yes the coupe models interchange with other coupes, sedans with sedans
I think you would need a 00-01 GSR b-pipe, but you couldn't use a 94-99 GS-R b-pipe. The 94-01 LS and 00-01 GSR exhaust systems are interchangeable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr_eg »</TD></TR><TR><TD CLASS="quote">b pipe? never heard that name before
b-pipe is a pretty common usage, it's also known as the mid-pipe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr (Exospeed) »</TD></TR><TR><TD CLASS="quote">I think you would need a 00-01 GSR b-pipe, but you couldn't use a 94-99 GS-R b-pipe. The 94-01 LS and 00-01 GSR exhaust systems are interchangeable. </TD></TR></TABLE>
94-01LS = 00-01GSR = ITR
I think I heard in another thread that a Civic Si 99-00 exhaust would fit an integra, but I am not sure if that is verified or which model and years it would fit. If I find that info I will let you know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr (Exospeed) »</TD></TR><TR><TD CLASS="quote">I think I heard in another thread that a Civic Si 99-00 exhaust would fit an integra, but I am not sure if that is verified or which model and years it would fit. If I find that info I will let you know.</TD></TR></TABLE>
I heard the same thing from someone else
Thanks!
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackSage »</TD></TR><TR><TD CLASS="quote">
94-01LS = 00-01GSR = ITR</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr (Exospeed) »</TD></TR><TR><TD CLASS="quote">b-pipe is a pretty common usage, it's also known as the mid-pipe</TD></TR></TABLE>
ahh gotcha...crazy CA talk i guess
yes they r interchangable
ding ding ding ding
ding ding ding ding
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr_eg »</TD></TR><TR><TD CLASS="quote">ahh gotcha...crazy CA talk i guess
I called it a b-pipe when I lived in VA too
</TD></TR></TABLE>I called it a b-pipe when I lived in VA too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr (Exospeed) »</TD></TR><TR><TD CLASS="quote">I called it a b-pipe when I lived in VA too
i just moved back up here from sc
NOW WHAT!!!
</TD></TR></TABLE>i just moved back up here from sc
NOW WHAT!!!
this is correct, the lengths are equal, although it probably doesnt pertain to your situation, you should keep in mind that the ITR has a larger diameter than the other 2.
WRONG!
It will not fit. I've tried it.
The stock LS piece is cast, the GSR is tubular, and the studs don't line up (not to mention the lengths are different).
i dont know what you are talking about. My post above is true because I bought an itr pipe for my 00 gsr. then when i returned it to stock i used a LS b pipe. all went in with NO modification
Wow, most of these answer are so wrong
If you're just changing the exhaust catback then yes only this years model fit:
The others GSR's dont.
Unless...
You change the whole exhaust systems meaning header and catback as is and swap it-
2dr to 2dr and 4dr to 4dr.
then they'll fit with no problem.
I hope most of you guys knows that if a 96-99 GSR header wont fit a Ls then why would the exhaust fit without any modification??
GSR exhaust piping is longer then Ls piping, because of the lengths different between the two headers.
I hope thats enough info, i have done it myself thats how i know.
The others GSR's dont.Unless...
then they'll fit with no problem.I hope most of you guys knows that if a 96-99 GSR header wont fit a Ls then why would the exhaust fit without any modification??
GSR exhaust piping is longer then Ls piping, because of the lengths different between the two headers.I hope thats enough info, i have done it myself thats how i know.
