tranny is hard to put in Reverse and sometimes 1st, whats wrong?
Old Oct 7, 2004 | 03:28 PM
oh-k's Avatar
Default tranny is hard to put in Reverse and sometimes 1st, whats wrong?
could i do anything to help with this problem? such as bleed cltuch, replace tranny fluid? please let me know, thanks.
Old Oct 7, 2004 | 03:33 PM
AWDxBOOST's Avatar
Default Re: tranny is hard to put in Reverse and sometimes 1st, whats wrong? (oh-k)
just normal for manual transmissions
Old Oct 7, 2004 | 03:37 PM
oh-k's Avatar
Default Re: tranny is hard to put in Reverse and sometimes 1st, whats wrong? (itr_eg)
when i go to do a three point turn i am there for like 2 minutes, while at the sametime blocking the road, trying to get it in reverse.
Old Oct 7, 2004 | 04:19 PM
Street Ghost's Avatar
throw it in a forward gear and leave it there for a sec.. then try to put it in reverese. sometimes it takes some force, sometimes it just glides in smooth. it's normal
Old Oct 7, 2004 | 04:42 PM
ECKSbloodECKS's Avatar
If it wont go into gear.......have it in neutral, let off clutch pedal all the way, put clutch back in, and try to put it in gear. Hope this helps
Old Oct 7, 2004 | 04:46 PM
(shockwave)'s Avatar
happens to a lot of people.
i have to fight with it some days to reverse our of my driveway. usually pushing it really hard to the right then down quickly will do the trick.
RidinStock's Avatar
Another trick is to try and roll a little, whether it's a quick nudge in first or a roll downhill, and it should be easier to get into reverse.
Old Oct 7, 2004 | 06:07 PM
jxj220z28's Avatar
Default Re: tranny is hard to put in Reverse and sometimes 1st, whats wrong? (RidinStock)
while pushing it in give the car a little gas and and it will slip in no problem
Old Oct 7, 2004 | 06:41 PM
spotch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Another trick is to try and roll a little, whether it's a quick nudge in first or a roll downhill, and it should be easier to get into reverse.</TD></TR></TABLE>
that always works like a charm for me. the slightest movement will make it much easier so you dont even have to be on a real hill, even slightly unlevel surfaces will work.
gq420j
Dec 24, 2007 08:58 PM
phoshizzle88
May 17, 2006 10:39 PM
Steezn4NOReason
Dec 29, 2004 06:26 PM
JDM_B18C5
Oct 4, 2004 12:29 PM
tilt
Oct 7, 2002 01:22 PM
