hard to install an alternator?
Old Oct 7, 2004 | 03:15 PM
LAKER HATER's Avatar
Default hard to install an alternator?
ive never installed an alternator before... is it difficult? whats required?
Old Oct 7, 2004 | 03:49 PM
PlastikOwl
Guest
Posts: n/a
Default Re: hard to install an alternator? (LAKER HATER)
it's a pain in the *** to get it out because of the clearance... but if you jack up the car enough it shouldn't be too much of a problem.
Get yourself a helms manual.
Old Oct 7, 2004 | 03:51 PM
..::91TEG-G2::..'s Avatar
Default Re: hard to install an alternator? (PlastikOwl)
i know that on the DA's theres a scrape plate built into the front bumper, and most of the time if its still there, you have to remove the bumper to get to it. like plastikowl said, clearance is a bitch, but once you do it once or twice, it'll get easier.
again, not sure on the skid plate for the DC's but someone can confirm
Old Oct 7, 2004 | 04:40 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: hard to install an alternator? (..::91TEG-G2::..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">i know that on the DA's theres a scrape plate built into the front bumper, and most of the time if its still there, you have to remove the bumper to get to it. like plastikowl said, clearance is a bitch, but once you do it once or twice, it'll get easier.
again, not sure on the skid plate for the DC's but someone can confirm</TD></TR></TABLE>
huh? Alternators have nothing to do w/ skid plates or the front bumper....
You will need to remove the driver side axle and maybe the halfshaft to get it out. It's really not that hard. If you can't get the axle off of the halfshaft, you can remove both as one unit, but you will either have to drain your transmission, or you can jack up only the left side of the car and you should be able to get the halfshaft out w/o having to drain anything.
Old Oct 7, 2004 | 08:45 PM
Default Re: hard to install an alternator? (PatrickGSR94)
[QUOTE=PatrickGSR94]
[QUOTE]
no, it being in the way. making it hard to access what you need to get too
Old Oct 8, 2004 | 05:28 AM
Community Builder
I have no idea what you're talking about on G2's... on G3's only the axle is in the way.
Old Oct 8, 2004 | 07:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I have no idea what you're talking about on G2's... on G3's only the axle is in the way.</TD></TR></TABLE>
k bro, dont get all hurt. i have a g2 and not a g3, so i was just sayin from what i know..
Old Oct 8, 2004 | 09:27 AM
Community Builder
nobody's hurt, I've never even seen what you're talking about. got any pics?
Old Oct 11, 2004 | 01:00 PM
sounds like a pain in the *** to do.
Old Oct 11, 2004 | 04:50 PM
r0nr0n's Avatar
k bro, dont get all hurt. i have a g2 and not a g3, so i was just sayin from what i know..</TD></TR></TABLE>
yo you need a new machanic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAKER HATER &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a pain in the *** to do.</TD></TR></TABLE>
it not that hard
Old Oct 11, 2004 | 05:48 PM
xyooj's Avatar
for mines...i took it out from the top. U gotta take a bracket off then finess that baby out. Drop the new one in and mount the bracket then the alte with the belt. 95 gsr though.
Old Oct 11, 2004 | 06:05 PM
stareatsun's Avatar
To change the timing belt, the heals says to remove the alternator and the ps pump. it says nothing about the axel so i think you can get it out another way.
JaeEK
11
Dec 7, 2007 07:22 PM
Demonis
Honda Civic (2006 - 2015)
Oct 27, 2006 12:36 PM
LillDragun
Jan 21, 2005 02:40 PM
geminis2k
Feb 5, 2004 10:00 PM
