car not idling right.....
Old Oct 7, 2004 | 03:04 PM
krazywhitboy's Avatar
Default car not idling right.....
i just did the mpfi swap on my 89 crx dx. i had a problem at first with the injector o-rings, but replaced those with oem one's and that solved it. the problem is now it will start and idle fine, but as soon as you give it some gas, and let off, it will sputter and die.....help!
Old Oct 7, 2004 | 03:37 PM
bump for some info.....
Old Oct 7, 2004 | 04:21 PM
barry11j's Avatar
Default Re: (krazywhitboy)
check the following....
fuel filter......
throttle position sensor .....
bad gas......
plugs.........
Old Oct 7, 2004 | 04:22 PM
barry11j's Avatar
Default Re: (barry11j)
is your check engine light throwing any codes...?
Old Oct 7, 2004 | 04:50 PM
ok i checked for codes and i'm getting a IAT sensor code. i'm pretty sure when i did the swap, i mixed up the IAT and EACV sensors so i think thats the problem. i'm also getting a Crank angle sensor code, but i think that is because when i wired the si dizzy plug to the dx harness, there were two solid white wires that i prolly got mixed up....i will keep you posted, thanks for the help...
civicb1812345
17
Aug 21, 2013 09:37 PM
MelloYelloCRX
May 5, 2007 06:10 PM
beatthisspeed69
Sep 26, 2006 07:44 AM
crex23
12
Aug 17, 2005 03:24 PM
see_our_vtec
Feb 25, 2004 08:41 AM
