can u weld stainless w/ a mig unit?
Old Oct 7, 2004 | 02:28 PM
fuzzynutz's Avatar
Default can u weld stainless w/ a mig unit?
im new to the welding thing i have a le weldpack 100 with the gas adapter i was wondering if i could weld on stainless?
Old Oct 7, 2004 | 03:19 PM
RCautoworks's Avatar
Default Re: can u weld stainless w/ a mig unit? (fuzzynutz)
Yep
Old Oct 7, 2004 | 07:55 PM
im sabah's Avatar
sure, just make sure you use correct wire and gas mix.
Old Oct 7, 2004 | 10:44 PM
Default Re: can u weld stainless w/ a mig unit? (im sabah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by im sabah &raquo;</TD></TR><TR><TD CLASS="quote">sure, just make sure you use correct wire and gas mix.</TD></TR></TABLE>
And that would be ?
Old Oct 8, 2004 | 11:41 PM
vtecngsr's Avatar
Default Re: can u weld stainless w/ a mig unit? (90blackcrx)
we used to use umm stainless wire.. and 95/5 gas
Old Oct 13, 2004 | 05:12 PM
fuzzynutz's Avatar
Default Re: can u weld stainless w/ a mig unit? (vtecngsr)
thanks alot guy i have some intercooler piping that i need to repair, so what should i set the pressure on the regulator at?
Old Oct 13, 2004 | 06:51 PM
eHoward's Avatar
308 filler and an argon/co2 mix gas.
I would just go to the welding shop, tell them what you're doing and let them hook you up. I've got an excellent shop around the corner from me though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">And that would be ?</TD></TR></TABLE>
precisionsc54
Welding / Fabrication
11
Jan 26, 2010 08:06 AM
akira712
17
Apr 2, 2007 12:32 AM
lewdude
14
Jan 26, 2005 06:05 PM
Dyno Queen
Jan 23, 2005 03:23 PM
civiceg500
11
Dec 26, 2004 04:13 PM
