I NEED HELP BAD
i have a 1991 honda civic hatchback (dpfi) now mpfi as of last weekend. i did a dohc zc swap. i was running sohc zc with dpfi intake stuff. now i have had the car running for less than a week and i am having major problems. i am running a pr4 ecu. i tried running a pg7 and it backfire through the intake. now when it does run with the pr4 it spudders alot. and when i come to a stop it idles odd. it idles from 1000 rpm to 2000 rpm back down to 1000rpm. and the ecu (pr4) keeps throwing code 12. i have a extra iacv. ijust want the car to run so i can drive it can any one please help me.
thanks lance
thanks lance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark91zc »</TD></TR><TR><TD CLASS="quote">i need to get a pm6. but i heard the pg7 is better than a pm6. is this true.</TD></TR></TABLE>
Better only meaning that it runs richer.
Are you sure you have a PG7?
I'm asking because the code 12 is an EGR code. I didn't think that PG7's even had EGR control.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Got a PM6 to try on with it?</TD></TR></TABLE>
Good idea to test the PM6. Check to see if you are still getting a code 12 with it.
i am running the pr4 ecu and it is throwing code 12 code 16 and code 43
i have not been able to get the car to run the pg7 yet
89civichatchback
Jul 24, 2003 12:57 PM
