Accord Headlight Removal
Old Oct 7, 2004 | 12:37 PM
BlaqK20's Avatar
Default Accord Headlight Removal
Does anyone have a DIY, or instructions of removing the stock headlights casing? Not just the bulb, but the whole unit. Any help would be appreciated. It for a 94-97 Accord 2 door.
Thanks in advance.
Old Oct 7, 2004 | 02:02 PM
THALADOR's Avatar
Default Re: Accord Headlight Removal (BlaqK20)
i heard you have to remove the whole bumper to get to all the screws, but i dont know of the specifics, i actually need to install a left headlight and clear corner myself.
Old Oct 7, 2004 | 04:22 PM
WanabVTEC's Avatar
Default Re: Accord Headlight Removal (battlofla)
no idea about headlight but i am pretty sure you don't have to remove the bumper for side marker lights...
Old Oct 7, 2004 | 05:04 PM
JayFI's Avatar
Default Re: Accord Headlight Removal (okiyani)
Yeep, I had to replace my right side headlight once, due to those moss/mildew growing inside the casing. Took it to a shop since I didn't know how. They informed me afterward that they had to take the bumper off.
Good luck.
Old Oct 7, 2004 | 05:31 PM
GqchYnAbOy's Avatar
I didn't take off my whoel bumper when i replaced my lights with JDM Style lights. I just loosened it enough and made sure I had enough room to unscrew the headlights
Old Oct 7, 2004 | 07:59 PM
itsmetyler's Avatar
you must remove the bumper first...then the side markers...i think there are 6 bolts to remove the entire headlight, you'll need a 10 mm socket...if you have anymore problems let me know
Old Oct 7, 2004 | 08:24 PM
BlaqK20's Avatar
Thanks for the replies. Any tricky screw/ hidden bolts i should look out for?
Old Oct 8, 2004 | 05:12 PM
bodiez's Avatar
Hit the floor!
Default Re: (BlaqK20)
Its not too hard. If yoiu have a manual everything is pretty easy. Hour job maybe.
510cd5
Aug 7, 2006 10:43 AM
Fuster_Cluck
Jun 14, 2006 08:37 AM
eauto
Jan 25, 2006 12:43 AM
cyb3rjak
Mar 26, 2005 05:46 PM
TxTuner
Aug 15, 2004 07:16 PM
