spun bearing
Old Oct 7, 2004 | 12:04 PM
Rasta's Avatar
Default spun bearing
when i start my car a loud tapping noise goes on for about 3 seconds, then after around 3k rpm the same noise happens and gets louder and louder as the rpm goes up. Would this be a spun bearing?
Old Oct 7, 2004 | 12:08 PM
boosted k20's Avatar
Default Re: spun bearing (BlitzkriegLs)
could also be a bent rod. bottom of the rod is probably hitting the bottom of the cylinder walls
Old Oct 7, 2004 | 12:11 PM
Rasta's Avatar
Default Re: spun bearing (boosted k20)
is it expensive to fix?
Old Oct 7, 2004 | 12:34 PM
rastropovitch
Guest
Posts: n/a
more than likely... could also be a bent valve but the b series are famous for spinning bearings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlitzkriegLs &raquo;</TD></TR><TR><TD CLASS="quote">when i start my car a loud tapping noise goes on for about 3 seconds, then after around 3k rpm the same noise happens and gets louder and louder as the rpm goes up. Would this be a spun bearing?</TD></TR></TABLE>
Old Oct 7, 2004 | 12:47 PM
PLAGUED_DB7's Avatar
Default Re: spun bearing (MSchu)
loud tapping or clicking?? could be time for a valve adjustment
Old Oct 7, 2004 | 12:51 PM
Rasta's Avatar
Default Re: spun bearing (theplague83)
its actually more of a loud tapping than a clicking.
Old Oct 7, 2004 | 01:17 PM
shamoo's Avatar
Will you make something up for me please?
You say the sound gets louder on higher rpm's. Does it also get faster?
A spun bearing would make noise like that, plus it would make noise all the time. How bout this....how fast is it actually? Is it so fast that you can't replicate the noise vocally? Or is it just fast enough where you can imitate it?
The reason I'm asking is to narrow down the choices. For example valve tap is VERY fast. You can't really make "clicking noises" with your mouth THAT fast. Where as rod knock/spun bearing/etc isn't AS fast and you can kinda make that sound.
Do I make any sense?
::imagines you making fast clicking/knocking noises with your mouth right after this post::
Old Oct 7, 2004 | 06:52 PM
Rasta's Avatar
Default Re: spun bearing (shamoo)
umm yeah pretty fast, cant imitate it. But if i keep the rpm below 3k it wont make the noise, only when i start the car.
Old Oct 7, 2004 | 07:07 PM
Big Bang's Avatar
sounds like when i spun my rod bearing....
Old Oct 7, 2004 | 07:17 PM
Default Re: spun bearing (The Converted)
better stop driving your car and change that rod bearing before u scratch up ur crank.
Old Oct 7, 2004 | 07:34 PM
Rasta's Avatar
any ideas how much for repairs?
Old Oct 7, 2004 | 07:37 PM
IN VTEC's Avatar
Sounds like a few marbles in your engine when you start it up and when you let off the gas?
You probably didn't spin the bearing, yet. The bearing is probably chewed and the clearance is really loose. Look to replace the rod and polish the rod journal.
Same thing happened to my engine.
Old Oct 7, 2004 | 08:08 PM
Quiks66's Avatar
Does is get louder with more throttle? If you can locate which side of the motor the sound is coming from, it might help.
Old Oct 7, 2004 | 08:14 PM
Rasta's Avatar
Default Re: spun bearing (Quiks66)
i dont know if it gets louder but it does get quicker. Ill find out what side its coming from though.
Rein4st
Jan 28, 2012 10:40 AM
SupaFly_Honda
Mar 1, 2007 12:48 PM
Touge Tuning
Jul 4, 2006 09:13 AM
Sephro
Nov 9, 2004 11:10 AM
