exhaust mid pipe question for integras
Old Oct 7, 2004 | 09:24 AM
rough_draft's Avatar
Default exhaust mid pipe question for integras
are the midpipes on 95-99gsrs the same as the midpipes on the 00-01 gsr? Thanks guys
Old Oct 7, 2004 | 09:28 AM
purplegsr's Avatar
Default Re: exhaust mid pipe question for integras (rough_draft)
No, the 94-99 GSR midpipes are a different length than the 00-01 GSR midpipes. However, 00-01 GSR exhaust systems are interchangeable with 94-01 LS/GS/SE exhaust systems, so I would assume those midpipes will be interchangeable.
Old Oct 7, 2004 | 05:32 PM
what length cat do i get then to run the jdm itr header on my 95 gsr exhaust?
Old Oct 7, 2004 | 07:41 PM
anyone have any more info on this? Thanks
Old Oct 7, 2004 | 08:04 PM
purplegsr's Avatar
Default Re: (rough_draft)
I am not sure offhand of the exact measurements. kteller8 or SMSP on this board can custom make one for your setup - they will use a carsound cat, add o2 bungs, and put the correct flanges to connect to a 2.5" collector and your exhaust piping. If you don't want to do that, you could just buy another high flow cat and have a portion of your b-pipe cut out and rewelded to compensate for the added length of the header.
civic1578
Oct 10, 2013 02:02 AM
AlxSiR7
Sep 27, 2004 06:12 PM
shhh151
Jul 30, 2004 11:23 AM
AintegraA
Dec 18, 2003 02:18 PM
supadupamikey
Sep 6, 2001 09:00 PM
