Help honda techs!!! No spark
Old Dec 14, 2001 | 03:13 PM
civicjunkie's Avatar
New User
Default Help honda techs!!! No spark
heres the lowdown
hybrid eg with type r swap
i am not getting any spark
can i replace the coil/ingniter in the distributor or am i shelling out for a new one???
thanks for the help!!!
Old Dec 14, 2001 | 03:20 PM
New User
Default Re: Help honda techs!!! No spark (civicjunkie)
ttt
Old Dec 14, 2001 | 03:39 PM
sgT's Avatar
sgT
yes, you can replace either one easily.
Are you sure thats the cause?
Old Dec 14, 2001 | 03:56 PM
IntegD's Avatar
New User
Default Re: Help honda techs!!! No spark (sgT)
well..if u dont have a voltmeter...just pull a plug wire off of the distributor about an inch...if ure not getting any spark..you can cancel out a fouled plug or a bad wire. My car died twice and it was the ICM once and the coil once...they are both simple to change...if you have a friend with the same motor...just try his coil and icm and see if it fires....good luck
Kyoto now
Aug 3, 2007 06:34 PM
94GsRacer
Jan 14, 2003 06:39 AM
sleepycivix
Nov 24, 2002 05:45 PM
