12.5:1 84mm bore safe?
Old Oct 6, 2004 | 10:48 PM
mattcivic's Avatar
Default 12.5:1 84mm bore safe?
i want to run 84mm 12.5:1 pistons in a non sleeved gsr motor if i add a block guard will this be ok to do i realy want to have it sleeved but that is a lot of money and if i can get away with not doing it ill run the block guard. i also want to run a 55 shot of zex if that makes it any worse.
DefiantGSR's Avatar
Default Re: 12.5:1 84mm bore safe? (mattcivic)
84 mm on stock sleeves is insane. sleeve.
Old Oct 6, 2004 | 11:31 PM
b19coupe's Avatar
Can I have your motor after you blow it up? 82mm is max on stock sleeves. 55 shot 84mm bore stock sleeves = BOOM!
Old Oct 7, 2004 | 03:44 AM
quickcarl's Avatar
Default Re: 12.5:1 84mm bore safe? (b19coupe)
You have to sleeve it to get an 84mm bore on a B16 or B18. We sleeve and build these all the time. The stock sleeve wall thickness isn't there.
Old Oct 7, 2004 | 12:33 PM
vtecdamian's Avatar
Default Re: 12.5:1 84mm bore safe? (quickcarl)
84.5mm and 12.5:1 here and after 15k miles o far so good 234 whp daily driven pump gas!
Old Oct 7, 2004 | 12:45 PM
AllMotorMadness's Avatar
Default Re: 12.5:1 84mm bore safe? (vtecdamian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecdamian &raquo;</TD></TR><TR><TD CLASS="quote">84.5mm and 12.5:1 here and after 15k miles o far so good 234 whp daily driven pump gas!</TD></TR></TABLE>
I think the guy is referring to stock sleeves on a gsr block. Max Bore you can go is 82mm. I don't know how you run run 84.5mm on a stock non sleeved gsr motor 15k miles unless your running a b20 block.
Old Oct 7, 2004 | 02:54 PM
mattcivic's Avatar
ok ok can anyone recomend a shop in washington state where i can get my gsr block sleeved? and i have heard u can hog out a stock b series to 84mm but if u guys say its 82 ill belive ya. well hhmm if im gunna sleeve it i might as well go with 86mm right? i guess my goal is 240 all motor hp at the wheels on pump gas ive got a gsr block and a b16 head help!!!!
Old Oct 7, 2004 | 03:36 PM
Odiedogcx's Avatar
AIRBORNE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcivic &raquo;</TD></TR><TR><TD CLASS="quote">ok ok can anyone recomend a shop in washington state where i can get my gsr block sleeved? and i have heard u can hog out a stock b series to 84mm but if u guys say its 82 ill belive ya. well hhmm if im gunna sleeve it i might as well go with 86mm right? i guess my goal is 240 all motor hp at the wheels on pump gas ive got a gsr block and a b16 head help!!!! </TD></TR></TABLE>
you can go to 84mm .. BUT YOU HAVE TO SLEEVE IT
86mm? Why not just got 89
Sleeve it to 84.5mm or 85.0mm.
240hp? What internals do you plan on running? Better break out the wallet or VISA
Old Oct 7, 2004 | 10:32 PM
mattcivic's Avatar
Default Re: 12.5:1 84mm bore safe? (Odiedogcx)
well fully balanced knife edged and micro polished crank eagle rods and 12.5:1 pistons and i live with my parents and have no bills o i have a few bucks to build a motor with say 86mm pitons in a gsr block and b16 head how big would the motor be? 1.9? 2.0?
Old Oct 7, 2004 | 10:49 PM
JL's Avatar
JL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcivic &raquo;</TD></TR><TR><TD CLASS="quote">well fully balanced knife edged and micro polished crank eagle rods and 12.5:1 pistons and i live with my parents and have no bills o i have a few bucks to build a motor with say 86mm pitons in a gsr block and b16 head how big would the motor be? 1.9? 2.0? </TD></TR></TABLE>
bigger than 2.0.. roslyn huh? thats deep! i also live in washington, sent my block to california but i'm sure there is shops that can do it here.. just have to find a reputable shop good luck with the build! you planning on going to pacific raceways next season when you get it finished?
Old Oct 7, 2004 | 10:55 PM
b19coupe's Avatar
Displacement = Pi(3.14) x 1/2 R (bore) squared x H (stroke) x 4 (# of cylinders)
Motor you are talking about = 3.14x 4.3(1/2 of 8.6 centimeters) x 4.3 x 8.72 x 4 = 2025 cc's.
All bore/stroke numbers are in centimeters because you are looking for displacement in terms of cc's (cubic centimeters).
Old Oct 8, 2004 | 01:35 AM
gldndrgn14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Displacement = Pi(3.14) x 1/2 R (bore) squared x H (stroke) x 4 (# of cylinders)
All bore/stroke numbers are in centimeters because you are looking for displacement in terms of cc's (cubic centimeters).</TD></TR></TABLE>
???? haha ive been out of schoolf for awhile. could you put that equation in laymens terms? haha
ok so its pi times 3.14(or are you stating pi is 3.14?)then multiplied by 1/2 of radius(stating radius is the bore?) then square 1/2 of the bore correct? then multiply the stroke multiplied by the cylinder?
or lets do this easier
pi x (1/2 bore squared)x stroke x #cylinders?
Old Oct 8, 2004 | 05:57 AM
b19coupe's Avatar
Default Re: 12.5:1 84mm bore safe? (gldndrgn14)
Pi is equal to 3.14.
The radius is the bore.
You take 1/2 of the bore and square it (times it by itself-i.e. 4.3 x 4.3 on a 8.6 centimeter [86mm] bore).
H (height) is the stroke-on a GSR/ITR it is 8.72 centimeters.
Once you multiply this all out, you have the volume of one cylinder. Then you just multiply the volume of one cylinder times the number of cylinders in the motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gldndrgn14 &raquo;</TD></TR><TR><TD CLASS="quote">pi x (1/2 bore squared)x stroke x #cylinders? </TD></TR></TABLE>
So what you have is correct
Old Oct 8, 2004 | 06:27 AM
AllMoToRB18c's Avatar
JG does 83mm with block guard on customers cars and they said they havent had a problem yet....i say do that
Old Oct 8, 2004 | 07:56 AM
Darton Sleeves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcivic &raquo;</TD></TR><TR><TD CLASS="quote">ok ok can anyone recomend a shop in washington state where i can get my gsr block sleeved? </TD></TR></TABLE>
Try Action Auto Parts and Machine @ 206-522-1822. They are in Shoreline, WA.
Old Oct 8, 2004 | 03:25 PM
mattcivic's Avatar
i usually go to renegade raceway just outside of yakima pacific is expensive and u get very few runs in. i do plan on making a few trips to pacific this spring though. yeah roslyn is deep not many tuners out here mostly on this side u see alttezzas aluminum spoilers and lots of stickers haha. thanx for all the info guys im gunna call action asap and get a quote from them im thinkin 84mm pistons i want to say i have a 2.0 well i guess it would be a 2.025 but u get the idea thanx again
Old Oct 8, 2004 | 06:07 PM
HoOridin's Avatar
JUST TRY IT AND LET US KNOW....
Old Oct 8, 2004 | 06:37 PM
superacecardriver's Avatar
Default Re: 12.5:1 84mm bore safe? (HoOridin_Kali_STyle)
I wouldn't recomend going .30 over on a stock sleeve. I don't even think Honda recomends it either.
Old Oct 8, 2004 | 06:42 PM
ArinX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoOridin_Kali_STyle &raquo;</TD></TR><TR><TD CLASS="quote">JUST TRY IT AND LET US KNOW.... </TD></TR></TABLE>
on stock sleeves lol while your at it shoot your self in the foot with the gun in his avatar
Old Oct 8, 2004 | 08:37 PM
HoOridin's Avatar
Default Re: 12.5:1 84mm bore safe? (ArinX)
i just wanna see someone do and blow it up and live to talk about it...now thats some gangsta $hit....
Old Oct 8, 2004 | 08:58 PM
ArinX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoOridin_Kali_STyle &raquo;</TD></TR><TR><TD CLASS="quote">i just wanna see someone do and blow it up and live to talk about it...now thats some gangsta $hit.... </TD></TR></TABLE>
lollll
Old Oct 8, 2004 | 09:49 PM
thad
Guest
Posts: n/a
i know a guy who bored an LS to 84 and ran11:1. i was supprise when it lasted all of two weeks.
Old Oct 8, 2004 | 11:00 PM
mattcivic's Avatar
**** it im gunna sleeve it i called action they can sleeve bore balance and blue print my block so u guys talked me into it. im gunna run 86mm pistons on darton sleeves 12.5:1 and a 55 shot any objections?
Old Oct 9, 2004 | 12:36 AM
Odiedogcx's Avatar
AIRBORNE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcivic &raquo;</TD></TR><TR><TD CLASS="quote">**** it im gunna sleeve it i called action they can sleeve bore balance and blue print my block so u guys talked me into it. im gunna run 86mm pistons on darton sleeves 12.5:1 and a 55 shot any objections? </TD></TR></TABLE>
just goooooood tuning and a good EMS
Old Oct 9, 2004 | 10:19 AM
WSU K20's Avatar
Im sure there are a few places on the west side, but over here on the east (spokane)I had my b16 block sleeved by precision balancing (509) 926-4832. We had them install 87mm darton sleeves into my b16.
