on going issue : cannot start after stalling on 91 accord
Old Oct 6, 2004 | 07:44 PM
91EXRMANUAL
Guest
Posts: n/a
Default on going issue : cannot start after stalling on 91 accord
i got a big problem and cannot seem to figure out whats wrong
every time now that i stall the car i cannot start it ... i sit around and have to wait 1-2 munits before i can start
has any one ran into this issue ?
Old Oct 6, 2004 | 09:16 PM
91EXRMANUAL
Guest
Posts: n/a
Default Re: on going issue : cannot start after stalling on 91 accord (91EXRMANUAL)
Could anyone diagnose the problem
Old Oct 7, 2004 | 12:29 AM
hawkmgc's Avatar
stalling as in, bad feet for clutch to gas?
If that is the case you might have flooded it when you stall. I know there was one person who had a bad Ignighter controler that was causing their issue.
Old Oct 7, 2004 | 12:49 AM
The_Todd's Avatar
Farts in the shower
Default Re: on going issue : cannot start after stalling on 91 accord (hawkmgc)
Typically you can't flood a fuel injected car...that usually happens on a carburetor fuel system; because its not electronically controlled. My guess would be main relay .
Old Oct 7, 2004 | 01:06 AM
hawkmgc's Avatar
Default Re: on going issue : cannot start after stalling on 91 accord (VRDrvr)
Yea you can flood an FI car/truck/SUV/RV/ATV
ask anyone who has either done it or spent the long hour it takes to unflood one with a torch and a sparkplug wrench.
Old Oct 7, 2004 | 01:12 AM
The_Todd's Avatar
Farts in the shower
I said typically you can't....
If your fuel injected car is flooding you have bigger problems.
Old Oct 7, 2004 | 02:58 PM
91EXRMANUAL
Guest
Posts: n/a
Main relay or flooding fi? where is the igniter located?
Old Oct 7, 2004 | 07:08 PM
91EXRMANUAL
Guest
Posts: n/a
When i Let the cultch out too qickly or forget im not in an automatic (stopping without putting in neutral) i stall
when i try and start it it will start then die then it wont start for a munit later
Ato Kad
Nov 10, 2017 05:27 PM
K00lGuy
Jan 14, 2016 10:49 AM
Ralph99
May 5, 2015 09:56 AM
QuickSilverZ
Sep 30, 2012 05:31 PM
