I think this is what i want my setup to be.
Old Oct 6, 2004 | 07:13 PM
rcurry14's Avatar
Default I think this is what i want my setup to be.
Ok the mods i would like to perform are:
440 injectors
hondata
b18c1 block-bored .25
jdm itr os pistons
buddy club 3+ cams
p&p head w/ valve job
port matched intake manifold and throttle body
3 inch short ram intake
full hytech exhaust system
2 layer headgasket
high compression valves
usdm itr transmission with jdm 4.7 final drive(lsd equiped)
Bridgestone potenza s03s
This all is in a 94 gsr after weight reduction it would probable weigh somewhere between 2500 and 2700. The compression ratio would be between 11.5 and 12:1 depending on weather i would use a 2 layer headgasket. SO do you all see anything that is missing or that shouldnt be in there? Do you think that this setup would be good enough for high 12's?
Old Oct 6, 2004 | 07:39 PM
98itr0448's Avatar
Default Re: I think this is what i want my setup to be. (rcurry14)
I don't know about high 12's, but maybe with a good driver and some sticky *** tires. You'll need some valve springs for those cams though. Personally I'd try to pick up compression other ways than a smaller head gasket. Sounds like a good setup though! You'll probably be around the 210-220hp range, but that's just a guess and will all depend on quality of the build and tuning. Good luck on 12's, I'd plan on 13's though.
Old Oct 6, 2004 | 10:42 PM
rjay8604's Avatar
Default Re: I think this is what i want my setup to be. (98Itr-0448)
I'm planning ~215whp in a ~2100 pound 91 hatch, and i expect high twelves, so figure with your weight.... For approximate estimate, look at power to weight ratio of vette's M3's AMG benz's and compare to their track times for a rough guide.
SteelcityLude
Sep 1, 2010 03:36 PM
vart
13
Nov 29, 2006 09:13 PM
94gsr18kid
Feb 9, 2005 10:23 AM
grenthang
Dec 25, 2004 02:46 AM
IntegD
Dec 5, 2001 06:26 PM
