Car starting problems, i think.
Old Oct 6, 2004 | 04:40 PM
90LSpimpin's Avatar
Default Car starting problems, i think.
Well, sometimes, at random, when i go to start my car, i turn the key all the way and nothing at all happens as if my battery was completely drained. Then i turn the key back to the off position, it makes the sound acknowledging that the key is in, and then it'll start up just fine. Also when this happens my clocks reset. And sometimes my clocks reset w/o the starting problem. I'm thinkin that the battery may be goin? But i dont have a voltemeter at my immediate disposal to test it. Any other suggestions are appreciated. Thanks!
Old Oct 6, 2004 | 04:44 PM
MENACE's Avatar
Default Re: Car starting problems, i think. (WeaponRex86)
Sounds like a bad ignition Switch. I had one go bad, the car just cut off while i was driving . I had to hold the key to get home.
Old Oct 6, 2004 | 05:15 PM
90LSpimpin's Avatar
Default Re: Car starting problems, i think. (MENACE)
Hmmm I'll keep that in mind. How bout this one: I went outside just now, and I opened the door, and my check engine light, oil light and battery light all came on and they go away when i close it. And I tried to start the car and I get absolutely nothing. Battery?
Edit: Just went outside to check my starter connections, and i moved the one that plugs into the starter like speaker wires connect, and it broke. Gonna try to fix it now, hopefully i have some of these connectors lyin around .
Old Oct 6, 2004 | 05:19 PM
MENACE's Avatar
Check all youre grounds to. Seem like you have some sort of a Electrical Problem. I would say its not the battery tho. But you should check all youre fuses and grounds.
Old Oct 6, 2004 | 10:06 PM
90LSpimpin's Avatar
Well, i fixxed the starter wire, and then examined the ground from the valve cover to the chassiss and it looked fine, but i reconnected it anyway, and the car works kinda fine. Still seems kinda weak though, like after the car sitting, the lights dont just click on, they kinda take a second to power up. I'm just gonna go through and redo all the grounds with new wires, and hope its not my battery or alternator.
dustin sterner
Jul 31, 2017 07:15 PM
sonscar
Jun 21, 2014 07:31 PM
JasonCRX
11
Aug 23, 2009 01:53 PM
solidsnakex37
Apr 19, 2008 11:45 AM
the.hamburglar
Aug 13, 2006 09:32 PM
