ahh SHIIIIIT, some how my factory alarm locked my keys in my car.. help meeeee
so in my 94 4dr im getting it ready to take htrew state patrol, so i let it idle for 20 minutes then drove it up and down my driveway TWICE, it started loosing power and smoking so i turned it off, jumped out and shut my door, found out that a water line burst( the hard line that is right by the hard line from the valve cover going into the intake) well the rubber end of the water hose broke so i went ot get my camera out of the car....and the doors dont open...and my keys are inside, the alarm is not on either
so how can i get in without damaging my car...?
ohh yeah my cars temp was like 3/4 up...is that bad
Your sig is FaWk|nG SicKK boiEEEeeee !!!
Just break a window with your elbow Fatboy. If it hurts, try a hammer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlphaQup »</TD></TR><TR><TD CLASS="quote">Your sig is FaWk|nG SicKK boiEEEeeee !!!
i know, it is....my dream car
breaking a window i would consider that but cleaning it up and replacing it is to much labor, as you said i am fat and i dont like to do stuff
</TD></TR></TABLE>i know, it is....my dream car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FatBoy4door »</TD></TR><TR><TD CLASS="quote">
If you take a (flathead) screwdriver I think you can pry the outer edges of the door handle off and should be able to open the door like that.
</TD></TR></TABLE>If you take a (flathead) screwdriver I think you can pry the outer edges of the door handle off and should be able to open the door like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iixerOii »</TD></TR><TR><TD CLASS="quote">
If you take a (flathead) screwdriver I think you can pry the outer edges of the door handle off and should be able to open the door like that. </TD></TR></TABLE>
Or... you could see if you left your moonroof cracked open. If Santa can do it, so can you.
bah, you have a 4 door. there aren't any seals on the windows, so just pull the window back, get a coat hanger and unlock using the auto locks.
If that doesn't work, then try the door handle trick
From: Salt Lake City, Chicago at heart, UT or IL, USA
hmmmm....what about a jimmy made out of a ruler or something along those lines?
or, you could call AAA. If that doesn't work, there's always AA
i pried the door handle out and it was hanging pretty far out but i couldnt get it unlocked, there are seals on the window i was trying to pop them off..but i couldnt figure out how,
i do not have a sunroof even though it is a ls
does anybody know if the trunk release cable goes outside of the car anywhere like the hood release cable does?
there r 2 ways that i can think of rite now.
#1 - Slim Jim
or
#2 - If u have the title or insurance card with ur cars vin # on it take it to a acura dealer and have them make a key for u. its only 2 dollars to do it and its the best way.
#1 - Slim Jim
or
simple..straighten out a clothes hanger (metal one) and make a loop a size of a quarter, then stick it through the crack between your door and the frame from the top of the car and try to get the door lock into the loop and pull up..ive done this 3 times and i finally got a spare
bro take a flat head screw driver and pry the frount window out of the the top where the window seals. then pull the window back enought to fit a close hanger down inside and un-lock it pulling the silver auto lock think up by your door handle
get a flathead screwdriver and stick it in the trunk key hole and start twisting that bitch ... my friend did that to my 94 and the trunk opened
the white smoke from the exhaust is a coolant leak. and technically ur not overheating your engine until it is in the red.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">94 Integra? Factory alarm? methinks not, they didn't come w/ any such device.
I smell alot of BS in this thread.</TD></TR></TABLE>
really? my '94 hatch (bought used) came with a remote that has that "A" on it and on the back it has another sticker with serials and stuff that says "Acura". and it doesn't look aftermarket, are you sure there wasn't an option from the dealer to have the alarm?
<thread jack sorry
> does anyone know how much to replace factory remote? mine died and i tried a new battery in it to no avail. i use keys only to lock the door.
<thread jack sorry
i call BS on this too. that damn car looks photochopped. and why do you have two screennames?
