D series one piece header into CRX...just unbolt crossmember to install?
Old Oct 6, 2004 | 02:45 PM
AgentJam's Avatar
Default D series one piece header into CRX...just unbolt crossmember to install?
Just checking before i do it...will i need to remove radiator/ac comp? or just take off crossmember...
It's the new strup performance header for d series (copy of dc) 4-2-1 one piece.
Vince
Old Oct 6, 2004 | 03:01 PM
unltdacc12's Avatar
Default Re: D series one piece header into CRX...just unbolt crossmember to install? (AgentJam)
all you gotta do is remove the bolt the goes through the front eng mount, and the four bolts that hold the crossmember up. That should give you enough clearance to install the header
ek/dta
Texas -OK -LA (Sales)
Mar 24, 2011 05:58 PM
Dahl Sol
Nov 30, 2009 01:51 PM
justinchodge
Apr 23, 2007 02:50 AM
