what would be the easiest way to do an dpfi to mpfi swap
Old Oct 6, 2004 | 01:51 PM
phamt2's Avatar
Default what would be the easiest way to do an dpfi to mpfi swap
So, is there a harness I can buy to do this? I mean, do I have to splice and connect wires if i want to do this swap? just wondering if there was an easy way to take care of it. thanks.
Old Oct 6, 2004 | 02:28 PM
Rywire's Avatar
Default Re: what would be the easiest way to do an dpfi to mpfi swap (phamt2)
You can send the dx harness to me, then all you would have to do is switch a few wires at the ecu.
PM me if interested.
Ryan
Old Oct 6, 2004 | 03:32 PM
CRX7's Avatar
Default Re: what would be the easiest way to do an dpfi to mpfi swap (droppedcrxsi)
Take his offer. This conversion along with B16a wiring took me a weekend to figure out what exactly to do, then another weekend to actually do it. And I actually spent this Saturday re-doing a lot of it as my original work wasn't up to par.
Old Oct 6, 2004 | 03:44 PM
Dwight Schrute's Avatar
Default Re: what would be the easiest way to do an dpfi to mpfi swap (CRX7)
if you have basic wiring skills ( soldering , splicing , depinning) and a good guide (search h-t) , it's not hard. it would probably take me a bit because i like stuff to be perfect. if ur time is worth a lot , it might be worth it in the long run to pay someone to do it if it's cheap enough.
Old Oct 6, 2004 | 04:31 PM
Super Chicken's Avatar
I took the main harness and the engine harness out of a wrecked Si and swapped everything over! had to do a little splicing between the main harness and the body harness as the donor was an 88' REX SI and it went into a 90' DX
89ED
Feb 20, 2015 11:27 AM
turboef90
Jan 29, 2013 12:26 PM
bbrian
Oct 22, 2005 11:18 PM
B2FiNiTY
17
Feb 25, 2004 03:22 PM
OutLuDeD
Aug 16, 2003 06:30 AM
