aiming HID's..
Old Oct 6, 2004 | 01:23 PM
JDM 93 EJ1's Avatar
Default aiming HID's..
hey guys i got a hella h4 hid kit in my ej1..bottom line is that i have adjusted these things by using the screws on the back of my oem usdm headlights..i have noticed that the headlight itself moves up down left and right..but i can't get them to sit level..does anybody have a better technique of aligning these things? my driver headlight aims alot higher then the pass..
Old Oct 6, 2004 | 01:27 PM
sohcvtec1995's Avatar
Default Re: aiming HID's.. (JDM 93 EJ1)
You will not get it perfect. Just get it the best you can and hope for the best. Also you could just get a set of projectors
Old Oct 6, 2004 | 01:28 PM
Default Re: aiming HID's.. (sohcvtec1995)
I thought they made HIDS illegal in NY if your car did not come with them from stock, since they are always stolen.
Hatchy-Ownzjo0's Avatar
H-T Poker champion
There should be 2 hot spots.. 1 for each headlight.. Is that what you can't get to line up?
I hope you are not talking about the GLARE.
You dont adjust your headlights with screws.. There should be BOLTS that you turn with a socket...
Old Oct 6, 2004 | 01:37 PM
JDM 93 EJ1's Avatar
Default Re: aiming HID's.. (Hatchy-Ownzjo0)
yea i believe i was using the bolts.not screw my bad..i was using whichever makes the actual housing move..and yes i do mean the hotspots..i can't get em even..here is a pic of my buried driver side headlight..and yet the driver side still has a much higher hotspot..if i'm about 20 feet from a wall the hotspot is about 5 feet higher then the pass..
Old Oct 6, 2004 | 01:56 PM
EK22snatch
Guest
Posts: n/a
damn dude, this is why i havent splurged on HIDs yet (well, and the cost too) but setting the lights up again in a total BITCH.
i havent ever seen a good how-to on this, but hopefully when you figure all this out youll be inclinded to share all of the techniques. i know itd sure help me, cuz ive tried setting lights up and i just gave up.
Old Oct 6, 2004 | 02:21 PM
JDM 93 EJ1's Avatar
bump for 411 on aligning my hotspots..
Old Oct 6, 2004 | 02:38 PM
MulletManRockStar's Avatar
Default Re: (JDM 93 EJ1)
go to a bodyshop they have tools for allinging head lamp beams
Old Oct 6, 2004 | 03:36 PM
CYM19z's Avatar
unfortunatley - yoru OEM honda HDlites wherent designed fo rtha HID lights & as so they do not direct tha light properly across tha road -- Your best chances to get realy good results from your HID - is to either go w/ some RICE projectors - or make your own using yoru lites & projectors from a bmw/audi/who-ever & just custom mount tha lenses w/ in your OEM lites. This set up will give u a much more focused beam of light & the light beam will be much less scattered - Also the Cut off line that HIDs w/ Projectors Produce, looks relaly Ill @ nite.
good luck w/ everything
HERE is a pic of milo's EG w/ HIDs w/ some projectors.
HERE is a pic of Andres-eh2's EG w/ HIDs w/ just OEM lites, NO projectors.
Images were obtained from this thread:::
https://honda-tech.com/ zerothread?id=626161
gtec8285
Jun 22, 2008 07:45 PM
Ruben19
Lighting
Nov 20, 2007 04:52 PM
The Epidemic
Lighting
Aug 25, 2007 10:46 AM
ssv05civic
Honda Civic (2001 - 2005)
Feb 19, 2007 04:06 AM
ChaseIntegra
Jan 19, 2005 05:19 AM
