ITR brakes upgrade
Old Oct 6, 2004 | 12:35 PM
Project X's Avatar
Default ITR brakes upgrade
Anyone who has upgraded to the ITR brakes notices more brake pedal travel than the stock Integra ones? Also, do you notice the initial bite is less, but once the pedal is more than 50%, then the grab is much more. Anyone know the reason behind this?
Old Oct 6, 2004 | 12:42 PM
SilverDc2's Avatar
Default Re: ITR brakes upgrade (Project X)
master cyclinder doesn't give it its full potential...its gonna wear out fast if you beat it....my friends did...u need a brand new ITR M/C
EDIT:...itr booster/prop valve..
Modified by SilverDc2 at 2:03 PM 10/6/2004
Old Oct 6, 2004 | 12:43 PM
ThePro's Avatar
I noticed a HUGE amount of pedal travel, but I later found out that I just still had air bubbles in the brake lines and that was the culprit. After that travel was the same as stock.
Bleed your brakes again. I don't remember if it is shortest brake line to longest or vice versa. Anyone?
And according Acura the ITR/GS-R use the identical master cylinders with the same part #.. so no problems there at all.
Old Oct 7, 2004 | 12:02 PM
Project X's Avatar
Default Re: (ThePro)
Hmm...the brake lines were bleed properly.
I found out from my mechanic saying that the reason for the ITR brakes to have more pedal travel is because the ITR brake calipers have bigger piston thus requiring more pressure to work it. Is this true?
Yes, the ITR/GSR/GS all have the same M/C. It says "1" on the side.
Old Oct 7, 2004 | 01:13 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: (Project X)
longest to shortest bleed order. I've heard to start the farthest away from the MC and work towards it. Haven't done it myself though. I don't trust myself with brakes.
Matt_EH3
Suspension & Brakes
Oct 25, 2016 08:31 AM
92integraVTECgsr
Dec 1, 2005 09:25 PM
92integraVTECgsr
Nov 7, 2005 09:15 PM
an2ny888
Oct 8, 2003 08:05 PM
