Help me adjust timing belt tension......pretty please??
Old Oct 6, 2004 | 11:22 AM
undertheradar's Avatar
Default Help me adjust timing belt tension......pretty please??
So as I posted before....I'm getting a ticking noise from somewhere (I can't isolate the noise) so I'm going to adjust the tension on the belt. I know that I need to
a: remove valve cover and upper timing belt cover
b: rotate engine a few times and set TDC
c: loosen timing belt tensioner half a turn
d: rotate cam gear 3 teeth counter clock wise to take up slack
e: tighten tensioner bolt back to specs.
Is that it?
My question is this: where the hell is the tensioner bolt. Is there access from outside the lower TB cover? When I look down there, under the motor mount, I see what looks like a plug of some kind. Is it behind this? How do I pull it out, or do get acces from the top and inside the lower belt cover.
Pics would be GREATLY appreciated.
Also....is it cool to just leave the upper TB cover off?
Old Oct 6, 2004 | 11:25 AM
cueballsi's Avatar
Default Re: Help me adjust timing belt tension......pretty please?? (undertheradar)
well yea behind the plug..there should be a little tab to pull on or use a flat head and pop it off...... in terms of tightening it not to osure ..... let me kow when u find out .. .thasnsk !
Old Oct 6, 2004 | 11:42 AM
Default Re: Help me adjust timing belt tension......pretty please?? (cueballsi)
Thanks....anybody else have any input?
Old Oct 7, 2004 | 12:06 PM
EK45VTi's Avatar
Disregard the marked area cos I used that picture for something else... since that one is the closest to what you need here it is:
Now, do you see the drivers side motor mount (near the PS canister)...
Well that bolt is UNDER IT... YOU CANNOT MISS IT... Some covers have open bolt, some have some kind of "cover" that is easily removed...
Old Oct 7, 2004 | 12:12 PM
EK45VTi's Avatar
Default Re: Help me adjust timing belt tension......pretty please?? (KKVTi)
Well, I found the drawing that might help you better...
There is a rubber plug that you must remove first...
Old Oct 7, 2004 | 12:16 PM
Thanks guys....I found it last night. Had to remove that plug. Also fixed the tapping noise I was having.
Old Oct 8, 2004 | 08:39 AM
EK45VTi's Avatar
Old Oct 8, 2004 | 09:01 AM
as a side note, this site
redpepperracing.com
has all the info neede avalable for viewing.
Modified by undertheradar at 6:38 PM 10/8/2004
Old Oct 8, 2004 | 09:37 AM
137's Avatar
137
touch my *****.
Modified by 137 at 11:06 AM 10/8/2004
Old Oct 8, 2004 | 09:39 AM
Default Re: Help me adjust timing belt tension......pretty please?? (137)
Thanks pig-******!
lsvteg11
Aug 20, 2009 10:32 AM
trecool44
Feb 3, 2006 05:47 AM
david90
Aug 28, 2003 08:31 PM
smkngsr
Jun 30, 2002 08:53 PM
