check engine light on.. throwing two codes!!!!
Old Oct 6, 2004 | 10:44 AM
92eh3si's Avatar
Default check engine light on.. throwing two codes!!!!
i just recently completed a jdmb18c swap into my eh3 si..
well, it is throwing two codes which are 15, 23.
found out that 15 is a ignition output signal and 23 is a knock sensor..
how do i clear these codes? how do i fix the problem?
could it be just the sensors it self? wiring?
need help!!
thanks
Old Oct 6, 2004 | 10:58 AM
Luserkid's Avatar
Default Re: check engine light on.. throwing two codes!!!! (92eh3si)
I had code 15 for the longest, it was my buddy. First off check the ignitor in the distributor, make sure its not burned or anything. More then likely you need to replace it.
Did you wire up the knock sensor correctly?
When your done with everything reset the ecu.
Old Oct 6, 2004 | 07:39 PM
92eh3si's Avatar
Default Re: check engine light on.. throwing two codes!!!! (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I had code 15 for the longest, it was my buddy. First off check the ignitor in the distributor, make sure its not burned or anything. More then likely you need to replace it.
When your done with everything reset the ecu. </TD></TR></TABLE>
this is my 3rd distributor and i don't think it is burned..
probably gonna replace the knock sensor with the one off of my z6
thanks a lot!!
DragInteg
Jul 20, 2005 01:25 PM
boostng r
Oct 26, 2004 11:49 AM
Phatch99
Jul 15, 2004 10:27 AM
DOHCtorTHRUST
Apr 18, 2002 11:43 PM
