Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
What pressures to start with?
Old Oct 6, 2004 | 09:23 AM
CivicSiRacer's Avatar
Default What pressures to start with?
This Sunday I will be trying out a new setup I'm been pondering for a couple of months.
2000 Honda Civic Si
350f/400r springs
Koni Yellows (off the shelf)
-2.8 front camber, -1.5 rear
0 toe front and rear
Comptech rear sway bar
What I used to have was 15x7" Kosei K1s with 45mm offset and 205/50x15" Azenis. Now I am going to try some 16x7" Rota C8s with 215/45x16" (about 1-2mm of tread on all tires).
What pressures do you guys recommend? I was using 34-36f/37-40r on my 205/50x15" Azenis.
Old Oct 6, 2004 | 09:50 AM
DerangedEG's Avatar
Default Re: What pressures to start with? (CivicSiRacer)
start with the same. You may have a little more grip in the front and rear so just start where you did before and play with them.
Old Oct 6, 2004 | 09:54 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSiRacer &raquo;</TD></TR><TR><TD CLASS="quote">
What pressures do you guys recommend? I was using 34-36f/37-40r on my 205/50x15" Azenis.</TD></TR></TABLE>
You're running higher in the rear? After I installed the Comptech bar on my EX, I started getting snap oversteer, and had to lower the pressures and soften the shocks in the rear (42f / 36r). I'm still trying to get it right so that the oversteer is predictable.
Old Oct 6, 2004 | 12:25 PM
Default Re: What pressures to start with? (EX_AutoXer)
When I tried 42f/45-47r I was getting snap oversteer. With my 205/50x15" at those above pressures it was just about perfect.
Well I went out on them today just to see and I didn't notice a HUGE gearing change - with the tires being almost bald. But they RUBBED so bad in the back and also they catch every road imperfection on the road. You have to keep both hands on the steering wheel. Grip feels much better, but we will see at Autocrossers Incorporated's autocross on Sunday.
blinx9900
Aug 16, 2007 05:27 PM
CivicSiRacer
Oct 31, 2004 05:22 PM
CivicSiRacer
13
Oct 26, 2004 11:36 AM
CivicSiRacer
22
Aug 3, 2004 08:57 PM
CivicSiRacer
Feb 12, 2003 12:41 PM
