swap
i was researching on how to put an h22a head on to and f22b block and found out that it would cost some money. Then i came across an article on the f23a1 head and was wondering if anyone knew anything about this swap. Leaving 4 basic traning really soon so trying to get started beore i leave.
just get a complete motor swap. less chance of something to go wrong. i got a f22b1 jdm motor dohc non-vtech with 160hp 148 tor for like 750$. and it bolts up to your stock tranny as far as i know
I say go with the whole swap if it's not a matter of money but if you want iron sleeves and you plan to boost this is a great alternative to the H23 swap. Low enough compression with iron sleeves.
and you dont have to send the block off to be sleeved for $$$$
This is just a cheaper alternative for a weekend mechanic.
and you dont have to send the block off to be sleeved for $$$$ This is just a cheaper alternative for a weekend mechanic.
