Recently Installed Skunk2 Manifold on GSR with Stock P72 ECU
Old Oct 6, 2004 | 08:52 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Recently Installed Skunk2 Manifold on GSR with Stock P72 ECU
Currently throwing a code 22 (Vtec malfunction). Replaced Oil Pressure switch. repalced Vtec Solenoid (Currently working/recieving 12 volts).
problem is @ 4800 rpm Vtec code 22 is thrown and car goes into limp mode (More like convulsions). As if redline is @ 4800.
PLS HELP.
Its for a friend of mine.
Also need to know if anyone has the original Skunk2 manual. It was lost during install (Don't ask).
Old Oct 6, 2004 | 12:04 PM
cjohnson_2's Avatar
Default Re: Recently Installed Skunk2 Manifold on GSR with Stock P72 ECU (Apex i ITR)
The other sensors that you had to disconnect when doing the manifold install. check them out #1. make sure you put the right ones in the right spot.
Old Oct 7, 2004 | 04:00 AM
Apex i ITR's Avatar
Default Re: Recently Installed Skunk2 Manifold on GSR with Stock P72 ECU (cjohnson_2)
Would anyone happen to have the Skunk2 manifold instructions on PDF or in text.
The mechanic who helped my friend install this lost the instructions and he is trying to trouble shoot it on his own.
Old Oct 8, 2004 | 03:05 AM
Apex i ITR's Avatar
Please help
krnboynemesis
Jul 4, 2005 11:13 AM
kboy01gsr
Nov 14, 2003 03:09 AM
DeDonDeRosa
Nov 5, 2002 09:24 PM
JDMkings
Oct 15, 2002 04:32 AM
C4wrx
Mar 5, 2002 04:49 AM
