Motor Mount
Old Oct 6, 2004 | 08:47 AM
kcirdnek's Avatar
Default Motor Mount
Is there an aftermarket company that makes motor mounts for a '98 EX-V6. This is the second front center dealer mount that I have broken. I need something more reliable, dependable, and stronger.
Old Oct 6, 2004 | 09:01 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Motor Mount (kcirdnek)
why not just put and insert in it or window weld it up?
Old Oct 6, 2004 | 09:53 AM
kcirdnek's Avatar
Default Re: Motor Mount (TouringAccord)
What is a window weld?
Old Oct 6, 2004 | 10:29 AM
H-T Order of Merit
It's a 3M caulk. You buy it in a normal caulk tube to use in a caulk gun. You basically fill the mount with it to make it solid just like putting in a insert. I'll see if I can find the link.
ok, here's a couple links for you.
Home Made Poly-Urethane Motor Mount
cpthaegdon
26
Jun 2, 2011 02:49 PM
See Are X
Sep 21, 2008 02:38 PM
408wdy
Apr 16, 2006 06:00 PM
DeeCeeTwo
Jul 19, 2005 11:32 PM
