99 B16B (CTR) Engine / 96-98 EX Engine Harness / into 96 EK Hatch Swap Question
Old Oct 5, 2004 | 08:53 PM
bsprelude's Avatar
Default 99 B16B (CTR) Engine / 96-98 EX Engine Harness / into 96 EK Hatch Swap Question
I have a 99 B16B (CTR) engine with a 96-98 EX (D16Y8) Engine harness with a OBDIIa Spoon Sports ECU. Am I going to run into any problems? This is all going into a 96 Honda Civic DX. I am mainly concerned with wiring problems!!!
Old Oct 6, 2004 | 11:19 PM
allmotorej8's Avatar
Default Re: 99 B16B (CTR) Engine / 96-98 EX Engine Harness / into 96 EK Hatch Swap Question (bsprelude)
with the 96-98 civic wireharness it should be a cake walk, the obd-2 wire harness are in one piece (to the engine to the ecu), wow that would be soooo easy!! should be no problem.
Old Oct 7, 2004 | 12:56 PM
4F_ Mugen CoL's Avatar
it should be easy, your car will be sick
Old Oct 7, 2004 | 03:52 PM
kidkombo's Avatar
Default Re: 99 B16B (jdmspoonfan)
good choice...
Old Oct 17, 2004 | 09:49 PM
ek_b16's Avatar
Default Re: 99 B16B (kidkombo)
I'm runing pretty much the same thing but a 00 si motor in my 97hatch. the only problem that you'll run into is the secondary o2 is missing. if you run a jumper back to obd1 then you'll have no codes but if not then what you can do is pull out the check engine light like how i did. keep me updated.
whyS0serious
33
Mar 28, 2012 10:50 AM
meccNme
Feb 28, 2012 01:54 PM
bsprelude
Feb 27, 2012 01:29 PM
91daINTEGRAda91
11
May 19, 2009 09:49 PM
bsprelude
Oct 5, 2004 09:04 PM
