Car keeps poping out of 5th Gear
Old Oct 5, 2004 | 08:28 PM
BLK99VTECR's Avatar
Default Car keeps poping out of 5th Gear
Well just as it say my car keeps poping out of 5th gear. To my understanding its not really a common problem. Does anyone know what usually causes this?, and what king of repair imma need. I know my clutch or pressure plate is bad, and i already have a new clutch awaiting a flywheel before install.
Old Oct 5, 2004 | 08:53 PM
DB8B20asic's Avatar
Default Re: Car keeps poping out of 5th Gear (BLK99VTECR)
I had that happen to my 91civic way back when..any how the guy that fix the problem tooled me it was my centroid's,man I hope I spelled that right.
Old Oct 5, 2004 | 09:07 PM
DubyaAye's Avatar
i had that happen to me and the only problem i had was tranny fluid was low.
Old Oct 5, 2004 | 09:51 PM
ProjectLSVTEG's Avatar
Default Re: Car keeps poping out of 5th Gear (DubyaAye)
synchro's?
Old Oct 5, 2004 | 11:53 PM
Curtisbeef's Avatar
Cant be the Synchro because Synchros only helps you change gears, it has nothing to do with holding the gear
Old Oct 5, 2004 | 11:57 PM
alfaaay's Avatar
Default Re: (Curtisbeef)
I've heard that it has to do with the forks being messed up. I've got a friend with the same problem on her EK, she has to hold it in 5th. Might wanna look into that.
Old Oct 6, 2004 | 08:27 AM
BLK99VTECR's Avatar
Default Re: (alfaaay)
yea i also heard the forks coud be a issue.
Old Oct 6, 2004 | 08:37 AM
turbodav's Avatar
Default Re: (BLK99VTECR)
check trans fluid if it is low it will pop out of 5th gear
Old Oct 6, 2004 | 09:09 AM
Sack Master's Avatar
Default Re: (turbodav)
Seriously change your fluid. I'll almost guarantee it will fix the problem.
Old Oct 6, 2004 | 10:33 AM
BLK99VTECR's Avatar
Default Re: (Sack Master)
just added some like 3 weeks ago
Old Oct 6, 2004 | 11:33 AM
Modified Motors's Avatar
check it again, happened twice with my eclipse and tranny fluid was bone dry both times.
Old Oct 6, 2004 | 11:52 AM
maziospzza's Avatar
how do you check the tranny fluid?
Old Oct 6, 2004 | 01:01 PM
B18C-VTI_R's Avatar
Default Re: (maziospzza)
how do you tfix the fork problem???????
jimmyrab
May 17, 2008 05:43 PM
indtegra
Nov 5, 2007 07:22 AM
Mike1995HondaPrelude
Sep 18, 2007 06:21 PM
bboyfreeze
Mar 26, 2007 06:41 AM
ragerized
Jul 11, 2004 03:53 PM
