Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Anyone have any experiences with Fluidyne radiators?
Old Dec 14, 2001 | 08:47 AM
4doorH22's Avatar
Default Anyone have any experiences with Fluidyne radiators?
At VIR this past weekend my radiator developed a hairline crack and coolant is steaming out ever-so-slowly. It's over 9 years old. Should I just get it patched, get a new/used OE replacement, or a high capacity unit like Fluidyne? Does anyone have any idea how much those Fluidynes cost? This engine has a hard life and I like to treat it as best I can [afford].
Thanks.
Old Dec 14, 2001 | 08:58 AM
Crack Monkey's Avatar
Default Re: Anyone have any experiences with Fluidyne radiators? (4doorH22)
The Fluidynes retail for $250+, as do most other high quality aluminum radiators.
OEM replacement should be around $150 (at least, they are for my RX-7).
Is the Prelude radiator larger than the one you are using? If so, you should probably upgrade. If they have similar capacities, and you are done tweaking the engine, then a OEM replacement should be fine.
Old Dec 14, 2001 | 09:00 AM
smokin rubber's Avatar
That sucks, Did you have any problems with cooling on the track? I seemed to be running in the middle all day long.
Old Dec 14, 2001 | 09:07 AM
4doorH22's Avatar
Default Re: Anyone have any experiences with Fluidyne radiators? (smokin rubber)
No cooling problems whatsoever. The temp gauge never waivers. It's a very slow steam leak; I guess it's on the upper tank. I dunno. Every time something goes on this car I tend to replace it with aftermarket (supposedly beefier) parts.
Some Accords and Preludes seem to share the same part number. http://www.absoluteradiator.com/
Old Dec 14, 2001 | 09:47 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
All I know is the Fluidyne is way lighter than most OE radiators. Ask alexboy, Ive seen his and it looks pretty.
Old Dec 14, 2001 | 09:51 AM
4doorH22's Avatar
Default Re: Anyone have any experiences with Fluidyne radiators? (Ross)
Yup, but add the weight of the extra liquid they hold, and any weight savings are pretty much gone I think.
Old Dec 14, 2001 | 09:56 AM
Ross's Avatar
25 Year Member
Community Builder
Could be true. His is for an Integra, so I'm not sure how much difference there is. It's quite possible the one for your engine is quite a bit bigger.
Old Dec 14, 2001 | 11:20 AM
ZygSpeed's Avatar
Here's another option: http://www.crracing.com/products/imports/
They're called C&R, I've spoken to them on the phone about one for my ITR.
The might also come with the FAL fans ...HTH
Old Dec 14, 2001 | 12:10 PM
civicrr's Avatar
Default Re: Anyone have any experiences with Fluidyne radiators? (zygspeed)
I think you will find the cost closer to $400. Not sure you could have yours repaired. Doesn't it have plastic end tanks? If so, you will be buying a new one. If you aren't having cooling problems, there really is no 'need' to get a Fluidyne. I purchased my last radiator from 1 800 radiators. It ended up costing me $112 including shipping.
Old Dec 14, 2001 | 12:30 PM
johng's Avatar
Default Re: Anyone have any experiences with Fluidyne radiators? (civicrr)
The full size Fluidyne radiators for the Integra are in the $350 to $400 neighborhood. These folks http://www.becool.com are proto-typing a new radiator for my car and will hopefully have a line of Import products soon. They currently don't anything available for the Honda in a direct "bolt-in-OE" application.
I should have mine in a few weeks. Stay tuned for updates since I'm the guinea pig
[Modified by johng, 1:33 PM 12/14/2001]
Old Dec 14, 2001 | 07:57 PM
fangtl's Avatar
Default Re: Anyone have any experiences with Fluidyne radiators? (johng)
I have a Fluidyne on my car, it has performed beautifully. I puchased mine at carparts.com with a $100 off 300 USD coupon, I am not sure if those are still available though...overall, I am very satified with the Fluidyne.
Old Dec 20, 2001 | 07:55 PM
Boosthead's Avatar
Default Re: I measured and remeasured and Investigated
I talked to C&R and got the specs for the 5th gen Accord and 93-96 Prelude radiators. The 94-97 accord will not fit. The mounting points are different. The 93-96 Prelude, however, appears to fit perfectly. I wussed out and bought a stock replacement from radiators.com instead, but hope this helps.
I think I still have the details on the Prelude radiator so let me know if I can help.
Old Dec 20, 2001 | 08:12 PM
four27's Avatar
Default Re: Anyone have any experiences with Fluidyne radiators? (fangtl)
fang-- what does the fluiddyne do that your stock radiator did not do? I mean we are talking a 400 option and I am having a hard time justifying one since I race my car in SCCA and if I wreck it now I have a 400 bill instead of a 150 bill for the rad and I dont see it making me any faster.
Old Dec 21, 2001 | 05:29 AM
4doorH22's Avatar
Default Re: Anyone have any experiences with Fluidyne radiators? (four27)
No faster of course. 30-50% increased (conservative estimate) cooling capacity/heat dissipation. Great peace of mind for those 95 degree summer days when your engine spends most of its time above 6,500 RPM. Heaven forbid my car ever hits anything... it's going to be at a velocity that causes more than 400 beans worth of damage and it's not my radiator I'll be worrying about.
Old Dec 22, 2001 | 10:28 AM
B18CJDM's Avatar
These are a "SPAL" lightweight fan not "FAL"
I know someone who runs an ITS Integra and he has a fluidyne as well as an oil cooler and says the car doesn't run as hot as he would like anymore and it is somewhat of an overkill, he wishes he would've just gotten a factory Integra radiator instead.
Old Dec 22, 2001 | 10:57 AM
4doorH22's Avatar
Default Re: Anyone have any experiences with Fluidyne radiators? (B18CJDM)
D'OH!
Old Dec 22, 2001 | 11:18 AM
Honda318dx's Avatar
That is what thermastats are for right?
Old Dec 22, 2001 | 11:40 AM
Mike P.'s Avatar
25 Year Member
Default Re: Anyone have any experiences with Fluidyne radiators? (Honda318dx)
Good point!
Old Dec 22, 2001 | 04:16 PM
fangtl's Avatar
The stock itr radiator was damaged during a vandalism last nov. the price of the fluidyne actually ended up being 30-40 USD lower than the OE radiator. Plus, I track the car occasionally during the summer (it gets up to more than 100+ on the track), and just wanted some peace of mind...
[Modified by fangtl, 8:18 PM 12/22/2001]
SeeJayLukas
Feb 26, 2018 08:41 AM
75aces
Feb 26, 2013 05:24 AM
FrostyDC4
Sep 4, 2004 08:33 PM
mickey513
Mar 18, 2004 06:18 AM
Driven
10
Jan 19, 2003 08:30 PM
