FS: NEW Esab Powercut 650 $1200.00
Old Oct 5, 2004 | 07:37 PM
STHPERFORMANCE's Avatar
Default FS: NEW Esab Powercut 650 $1200.00
Thats right, $1200.00.
Its brand new, Still has pull ties on all the cords.
Located in central PA if u wanna pick it up.
If it needs to be shipped i can arange shipping.
Powercut 650 Cutting Package Includes
- Manually cuts 5/8 inch and severs 3/4 inch - powerful cutting performance.
- Economical price - tremendous plasma cutting value for the money
-Compact portable design - goes to the job, easily moved
- Delivers big machine cutting power in a rugged, lightweight package.
- Arrives ready to cut, with torch connected and front-end parts in place, for the ultimate in operator convenience.
- High frequency starting - starts through paint.
- Trigger lock-in for long-cut operator comfort.
- Adjustable output - tailor the current to the material being cut.
- Compact, simple torch - easy access, little maintenance.
- New quick-connect torch switch plug
- New durable torch cable prevents snagging on fixtures and materials
- Patented XT nozzles - extended shape gives good visibility as well as good consumable life
- Drag or standoff cutting - easy operation with little or no training.
- Template following feature - easily duplicates curves or straight lines
- Tolerates poor power lines
- Three-year warranty on Console
- One-year warranty on Torch
Specifications:
Cuts 5/8", severs 3/4"
Output: 40% duty cycle-40A/120V, 60 % duty cycle-30A/120V, 100% duty cycle-22A/120V
Output Current Range: 10 to 40 Amperes
Open Circuit Voltage: 290 VDC Nominal
Input @ 35A/120V: 208/230 VAC 1 ph. 50/60 Hz, 35/32 amps
Power Factor @ 40A Output: 76% (1 phase)
Efficiency @ 40A Output: 85% (typical)
Air Requirements: 250 cfh at 80 psig
Weight (less torch & work cable): 53 lbs.
Vouch thread in SiG,
Contact me at
AIM: Boosted4g
EMAIL: scottherman@suscom.net
Old Oct 6, 2004 | 02:02 PM
Default Re: FS: NEW Esab Powercut 650 $1200.00 (Tha Shocka)
UP....
Old Oct 6, 2004 | 10:51 PM
To the top....
Old Oct 7, 2004 | 11:27 AM
To the top...
Old Oct 7, 2004 | 02:07 PM
To the top, Entertaining offers
Old Oct 8, 2004 | 10:58 PM
Anyone wanna make a offer at all ???
Tchleung
Mar 5, 2005 06:59 AM
