anyone use a shear/punch type tubing notcher???
Old Oct 5, 2004 | 04:20 PM
turbodude's Avatar
Default anyone use a shear/punch type tubing notcher???
I am looking to buy a new notcher, and wonder if anyone has one of these. Doyou like it, do you think its better than hole saw type?? How many times does one shear last for. Thanks
Old Oct 6, 2004 | 01:32 PM
Doctor CorteZ's Avatar
Default Re: anyone use a shear/punch type tubing notcher??? (turbodude)
for cage work ?
Old Oct 6, 2004 | 03:31 PM
turbodude's Avatar
Default Re: anyone use a shear/punch type tubing notcher??? (Doctor CorteZ)
yes for cage work. I do not have enough money to invest in a mill type notcher.
Old Oct 6, 2004 | 04:57 PM
legendboy's Avatar
I've been drawing up plans to make myself a tubing notcher. 1hp electric single phase motor. Custom turned end mill holder and coupler to motor shaft. Pillow blocks. Custom turned roughing end mill shanks and a cross sliding vise. Should be pretty sweet. Cost around 1k with a range of sized end mills.
Old Oct 7, 2004 | 05:23 AM
bigTom's Avatar
Default Re: anyone use a shear/punch type tubing notcher??? (legendboy)
i first tried using a horizontal mill and set it up with v-block in the vice... i just couldnt get it to work... to machine had too many ajustments on it that the whole table would always move... i ended up getting the mb one (pictured above)... it makes everything so much easier
oh... DONT cheap out on the endmills... i tried cheaper ones or re-cut ones at first and they just didnt work... they wore out way to fast didnt like 4130 too much to sy the least
Old Oct 7, 2004 | 05:57 AM
legendboy's Avatar
Default Re: anyone use a shear/punch type tubing notcher??? (ek9t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t &raquo;</TD></TR><TR><TD CLASS="quote">i first tried using a horizontal mill and set it up with v-block in the vice... i just couldnt get it to work... to machine had too many ajustments on it that the whole table would always move... i ended up getting the mb one (pictured above)... it makes everything so much easier</TD></TR></TABLE>
Should have worked perfectly with a milling machine!
Old Oct 7, 2004 | 06:06 AM
bigTom's Avatar
it was with a milling machine! cheap one i found on ebay though
Old Oct 7, 2004 | 12:11 PM
legendboy's Avatar
haha maybe its time to take a night class!
Old Oct 7, 2004 | 12:20 PM
c jackson's Avatar
threes
we have that mill at the shop. works great
Old Oct 7, 2004 | 02:35 PM
turbodude's Avatar
so no on has tried a shear notcher before... ?
Old Oct 7, 2004 | 05:22 PM
RenoRacing's Avatar
Default Re: (turbodude)
Those things are really nice. Annular cutters I believe is what they are called and they make very clean and fast cuts!
yamaha6611
Jul 19, 2012 10:24 PM
SilverWarrior
Welding / Fabrication
Jun 4, 2007 10:01 AM
nvrydaz
Jun 2, 2007 12:15 PM
NACvicSi
Oct 13, 2005 11:31 AM
