Apexi N1 99 spec coilovers - how to adjust dampening?
Old Oct 5, 2004 | 04:03 PM
98DC2R's Avatar
Default Question about Apex-i N1 99 spec coilovers
I just bought some Apex-i N1 99 spec coilovers for my R and was wondering how do you adjust the damping? Or are these non adjustable? The seller said you can put a allen in the shaft and it will click, but doesnt seem to be anything in there to turn?
Any help from anyonw would be great.
Old Oct 5, 2004 | 05:17 PM
yellow blur's Avatar
Default Re: Question about Apex-i N1 99 spec coilovers (98DC2R)
It's a 5mm allen (long) you need to stick down the shaft.. and you will feel if not hear the clicks. Right makes it stiffer, left makes it softer.
Old Oct 5, 2004 | 05:40 PM
KetteringITR's Avatar
Default Re: Question about Apex-i N1 99 spec coilovers (yellow blur)
yea i jus bought the same suspension used and it came with an allen wrench and i was wondering wat that was for. Now i kno. o and on a side note: fronts are on but rears had one bushing where it bolts into the LCA was zapped right out. Yea poo on that one . anyone got any ideas if i can order the bushing from apexi direct?
Old Oct 5, 2004 | 08:53 PM
BolivianDc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow blur &raquo;</TD></TR><TR><TD CLASS="quote">It's a 5mm allen (long) you need to stick down the shaft.. and you will feel if not hear the clicks. Right makes it stiffer, left makes it softer.</TD></TR></TABLE>
yea turn the **** all the way to the right for full stiff, then if i remember right 13 clicks down is the softest setting, any clicks after that won't do anything.
Old Oct 5, 2004 | 10:30 PM
dunce11r's Avatar
Default Re: Question about Apex-i N1 99 spec coilovers (BolivianDc2)
yep... clockwise ALL the way is full stiff, and 13 clicks CCW is softest... any further and its useless......
ALSO, make sure you install the coilovers CORRECTLY....
you use the middle collars to "preload" the spring... its not really used to control height like all the other coilovers....
instead, to control height, you loosen the very bottom collar, and rotate the part where it connects to the LCA... i repeat, DO NOT use the middle collars to adjust height.. you can to an extent, but i wouldnt preload teh springs too much... i called apexi direct for this info...
Old Oct 6, 2004 | 10:48 AM
98DC2R's Avatar
Default Re: Question about Apex-i N1 99 spec coilovers (dunce11r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunce11r &raquo;</TD></TR><TR><TD CLASS="quote">yep... clockwise ALL the way is full stiff, and 13 clicks CCW is softest... any further and its useless......
instead, to control height, you loosen the very bottom collar, and rotate the part where it connects to the LCA... i repeat, DO NOT use the middle collars to adjust height.. you can to an extent, but i wouldnt preload teh springs too much... i called apexi direct for this info...</TD></TR></TABLE>
Thank for all the feedback , apex-i website was useless. I knew the peps on H-T would come thru.
I dont understand what u mean by "preload the spring" ? I ve heard of this term before but dont know what it means, any help would be great!
Old Oct 6, 2004 | 11:11 AM
travanx's Avatar
I still don't get the preloading of the spring. I have a dc5 with the type-v coilovers and everyone says to not preload the spring. Then what is the point of those collars on the spring??? Maybe someone can explain in more detail the point of being able to preload when it seems like everywhere I read says to not preload.
BTW preloading is when you turn the collars under the spring to compress the spring before you lower the car. This makes the spring compressed more all the time. So its like making the spring stiffer without having a stiffer spring. But there is some movement that gets affected because you are now making the spring have less movement then it was designed for.
And of course you pay more for this type of coilover because you can adjust the height independantly (sp?) of the rest of the system. So other coilovers you adjust the height by preloading the spring. Clarify that part if I am wrong, but I don't know too much about the other type.
ProjectEG6R
Suspension & Brakes
Nov 7, 2008 05:45 PM
DrVtec99
Suspension & Brakes
Jul 23, 2007 05:45 PM
d1deez
Feb 10, 2004 02:25 AM
d0nkeyxPunch
Mar 11, 2003 10:24 AM
