timing belt
Old Oct 5, 2004 | 02:26 PM
docbrad's Avatar
Default timing belt
i'm driving an automatic 1999 accord with 90,000 miles on it. when do i need to get the timing belt changed? i have heard from 75,000 to 105,000.
Old Oct 5, 2004 | 02:34 PM
Accord2NR's Avatar
Default Re: timing belt (docbrad)
i heard it was at 100,000
Old Oct 5, 2004 | 02:54 PM
sj993's Avatar
Default Re: timing belt (iLoVeMyF22)
Supposed to be changed at 90K.
Old Oct 5, 2004 | 03:42 PM
slpycd7's Avatar
It is recommended that you change the timing belt every 60k miles. I have seen them last up to 100-105k. I would recommend you change that thing before something worse happens. Unless you want your motor to go so you can do a motor swap
Old Oct 5, 2004 | 05:22 PM
Razor's Avatar
Default Re: timing belt (slpycd7)
90k miles or 6 years, whichever comes first.
Old Oct 6, 2004 | 02:14 AM
1998hondaaccord's Avatar
Default Re: timing belt (Razor)
Honda reccomneds changing the belt at 105,000 unless you live in very cold or hot climates.
I had one last 150,000 miles.
Old Oct 6, 2004 | 03:25 AM
James's Avatar
Default Re: timing belt (1998hondaaccord)
it has been mentioned several times on this forum - perhaps you could use search a little before asking this question.. no offense here.
Old Oct 6, 2004 | 03:46 AM
TouringAccord's Avatar
H-T Order of Merit
You should replace it now. Run a search on timing belt in the archives as well and recent and you will find some good info on it.
Old Oct 7, 2004 | 07:45 PM
Razor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1998hondaaccord &raquo;</TD></TR><TR><TD CLASS="quote">Honda reccomneds changing the belt at 105,000 unless you live in very cold or hot climates.
i work at a honda dealership and i have never heard this, only 6 years or 90k miles.
Old Oct 7, 2004 | 07:47 PM
specie's Avatar
One more time for 90k. Just had mine done today also.
Old Oct 11, 2004 | 11:23 PM
Default Re: timing belt (specie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Razor &raquo;</TD></TR><TR><TD CLASS="quote">
i work at a honda dealership and i have never heard this, only 6 years or 90k miles.</TD></TR></TABLE>
Older hondas are recommended at 90k, 6th gens like mine are at 105,000
Talk to the service dept or look in the owners manual.
Vikings
Jun 11, 2018 05:44 PM
newbie2012
Oct 26, 2012 11:14 AM
zekeharley
Oct 26, 2006 03:39 PM
serious
Nov 11, 2005 11:32 AM
civickidd99
Aug 11, 2003 01:54 PM
