1992 honda civic cx swap
Old Oct 5, 2004 | 02:11 PM
brandonbeeb's Avatar
Default 1992 honda civic cx swap
hey guys i was wondering about a swap my cx isnt running right now and it wasnt the alternator and i can eitehr get a new head or i can go with a d16z6 and is there anything else i need to drop it into my hatchback ?
Old Oct 5, 2004 | 02:15 PM
Street Ghost's Avatar
Default Re: 1992 honda civic cx swap (brandonbeeb)
Go with the D16Z6, it's pretty much a bolt-in affair except you may need to do the VTEC wiring.
Old Oct 5, 2004 | 02:21 PM
HATCHingMN's Avatar
save money for a B16a gen.II
or an LS swap is pretty good
basically any other motor then your cx motor is a big upgrade
Old Oct 5, 2004 | 02:24 PM
CivicEX96's Avatar
Default Re: 1992 honda civic cx swap (HATCHingMN)
check out this swap info thread...
https://honda-tech.com/zerothread?id=878010
it might help you in your decision
Old Oct 5, 2004 | 02:25 PM
pane93civhb's Avatar
cx motor sucks. i started with it. then i got the sohc vtec zc motor just like the d16z6 except its jdm. then i traded that one for an ls motor which i am happy with but after all that i still wana build or get an h22a so just get a cheap motor now better then the cx motor which is anything. and then save for what u really want.
Old Oct 5, 2004 | 02:27 PM
Default Re: 1992 honda civic cx swap (pane93civhb)
the thing is i wanna turbo it, or i guess if i went with a b16 id be fine, i live in canada and can do the swap myself but i donno i wanna save money, wat is better for my situation an ls or a b16 like power wise, cause id like to get my car running soon so anyhting other then the stock motor is amazing
Old Oct 5, 2004 | 02:31 PM
EGinNY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brandonbeeb &raquo;</TD></TR><TR><TD CLASS="quote">the thing is i wanna turbo it, or i guess if i went with a b16 id be fine, i live in canada and can do the swap myself but i donno i wanna save money, wat is better for my situation an ls or a b16 like power wise, cause id like to get my car running soon so anyhting other then the stock motor is amazing</TD></TR></TABLE>
read what he said...answers all your questions (including which to turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicEX96 &raquo;</TD></TR><TR><TD CLASS="quote">check out this swap info thread...
https://honda-tech.com/zerothread?id=878010</TD></TR></TABLE>
EDIT: IMO...The d16z6 will be your best bet...the 92 cx is already wired for vtec....get a d16z6 WITH the engine harness and a p28 computer (92-95 ex/si) all PLUG-N-PLAY
did it to my 92 cx in a few hrs in my driveway
cost me about 500 for everything
Old Oct 5, 2004 | 02:53 PM
Default Re: 1992 honda civic cx swap (EGinNY)
the 92 cx is not wired for vtec so u will have to run the wires. man. and its not all that hard. u should use the sohc vtec engine harness if u have that option though. becuz u will be able to see where on the engine harness u need to run the 2 vtec wires from.
Old Oct 5, 2004 | 02:59 PM
EGinNY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pane93civhb &raquo;</TD></TR><TR><TD CLASS="quote">the 92 cx is wired for vtec so u will not have to run the wires. man. and its not all that hard. u should use the sohc vtec engine harness . </TD></TR></TABLE>
^^ Fixed it for ya....
boosted civic 2k6
Aug 30, 2005 06:46 PM
hondarookie10
Dec 19, 2003 11:34 AM
SLowCrx
12
Aug 3, 2002 11:18 AM
drvfast
Jul 25, 2002 09:52 AM
