brake pads
Old Oct 5, 2004 | 01:10 PM
intezn's Avatar
Default brake pads
I am almost to a point where i need to replace my front brake pads.
Since I have extra pads laying around from other car, one set from a 99 civic ex 4 door and a set from a 95 LS, would these pad work on my car, it's a 92 civic si.
thanks
I been searching and found somewhat the answer which is no, anyone can confirm that?
Old Oct 5, 2004 | 01:42 PM
civicboisi's Avatar
Default Re: brake pads (intezn)
i dought it would fit your caliper now...easiest way to find out is to ask for the two seperate pads and see if the numbers are the same...which i dought they are...good luck!
Old Oct 5, 2004 | 01:50 PM
pdiggitydogg's Avatar
both are too large
I guarnatee that
Old Oct 5, 2004 | 02:18 PM
Street Ghost's Avatar
Default Re: (pdiggitydogg)
If your Si brakes are stock, then they won't fit. You have the smaller calipers made for a 9.x" rotor, whereas the calipers on the 99 Civic EX and Integra are for 10.3" rotors and are larger.
DarryCar
Suspension & Brakes
33
Mar 10, 2016 07:08 AM
1SikEagle
Oct 20, 2008 07:26 PM
BLKCivicPorscheStyle*
Suspension & Brakes
Sep 6, 2006 07:26 PM
civicboy95
Jun 21, 2004 12:44 PM
