which heat shields for jdm 4-1
Old Dec 14, 2001 | 05:34 AM
comptechgsr's Avatar
Default which heat shields for jdm 4-1
which heat shields do i need to fully "cover" the header as to make it look "stock" to ur everyday ricer....
can i jus get the upper one?
Old Dec 14, 2001 | 05:52 AM
Brian's Avatar
Default Re: which heat shields for jdm 4-1 (comptechgsr)
The upper one in the front of the engine will cover it and make it look stock.
Old Dec 14, 2001 | 05:51 PM
wreckedagain's Avatar
Default Re: which heat shields for jdm 4-1 (QuickType-R)
anyone know where to get jdm heatshield?
Old Dec 15, 2001 | 07:31 AM
Comtechgsr2000s's Avatar
New User
Default Re: which heat shields for jdm 4-1 (wreckedagain)
Inlinefour or JDM honda
Old Dec 25, 2001 | 04:10 PM
AllMotorITR's Avatar
New User
Default Re: which heat shields for jdm 4-1 (Mugenblkgsr2000)
Yeah I would get JDM Heatshields... The Upper will make it look stock, but then again, the lower one with prevent scraping the header when going over a speed bump.. Try either David or Mike.
Old Dec 26, 2001 | 03:34 PM
1fastGSR's Avatar
New User
Default Re: which heat shields for jdm 4-1 (1 FAST R)
I bought the lower one for that reason.
Old Dec 26, 2001 | 05:04 PM
Chris's Avatar
Default Re: which heat shields for jdm 4-1 (1fastGSR)
The lower one will not prevent the header from getting damaged. If you are going to hit anything, that flimsy little piece of sheetmetal wont help much.
Old Dec 26, 2001 | 05:10 PM
ingrate's Avatar
25 Year Member
Default Re: which heat shields for jdm 4-1 (Chris)
if you are going to drive your car through tall, dry grass on a hot summer day then i would go ahead and get the lower shield
Old Dec 26, 2001 | 05:17 PM
1fastGSR's Avatar
New User
it's helped me
riceball777
Apr 24, 2007 09:20 PM
1 speedstar
Jan 23, 2003 12:42 PM
onyx00
Jul 20, 2002 10:01 AM
onyx00
Apr 3, 2002 04:16 PM
StinkyTofu
Nov 5, 2001 09:05 PM
