Coolant Leaking Inside Car After Swap - HELP!!!
Old Oct 5, 2004 | 10:39 AM
Hybrid2Be's Avatar
Default help me.
i have coolant leaking inside my car after the swap. i hoping it's not the heater core because the car was fine before the swap. could it be the lines by the firewall? any info would help. thanks
Old Oct 5, 2004 | 10:45 AM
Luserkid's Avatar
Default Re: help me. (Hybrid2Be)
What do you mean by coolant? Do you mean Anti Freeze?
Do you still have your AC? I would check those lines. And what part of the car is it leaking in?
Old Oct 5, 2004 | 10:50 AM
XoUnKoWnXo's Avatar
also what type of swap and what car is it going into?
Old Oct 5, 2004 | 11:00 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: help me. (XoUnKoWnXo)
Check the heater hoses going into the heater core - one of them is probably loose or pinched, or the hard brass lines might be crushed.
Old Oct 5, 2004 | 11:37 AM
SkoundrelUSA's Avatar
cute little bastard
check all ur hoses make sure they're tight, also check ur bleeder valve and make sure thats tight. sometimes the stupidiest things cause the stupid problems
edit: whoops i read it wrong my bad
Modified by SkoundrelUSA at 6:44 PM 10/5/2004
Old Oct 5, 2004 | 01:40 PM
Hybrid2Be's Avatar
thank you.. i'll mess with it tonight.. and update you guys tomorrow on the situation.
Old Oct 5, 2004 | 01:47 PM
wHOAlly's Avatar
Default Re: help me. (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">hard brass lines might be crushed.</TD></TR></TABLE>
if its leakin inside the car and collects at the front footwells, i gaurantee you its that
Old Oct 5, 2004 | 02:23 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: help me. (Sp00n'd Supra)
Check your HEATER CONTROL VALVE
Old Oct 5, 2004 | 02:24 PM
Default Re: help me. (BrokeAssPinoy)
As well as your heater hoses
Old Oct 5, 2004 | 03:27 PM
Hybrid2Be's Avatar
what could be wrong with the valve? and how would it leak from the valve to inside the car? maybe this might help.. the heater works, warm when idle.... but hotter when you're driving? thanks
Old Oct 5, 2004 | 04:49 PM
New Image's Avatar
you are going to have to get a flashlight, get your car in the air, start it up, get a pan to collect the coolant, climb under and follow the leak. could be a small hole in one of the hoses at the firewall or just a loose hose clamp, that happened to me. easy fix. good luck.
Old Oct 6, 2004 | 10:05 AM
Hybrid2Be's Avatar
well. i checked all the lines.. made sure all the hoses were clamped down. one of them wasn't clamped down completely i felt some coolant leaking from there, so i clamped the hose, ran the car for about 20 min let it sit over night everything seemed fine no leaks when i woke up. thanks for all the help.
Old Oct 6, 2004 | 12:08 PM
New Image's Avatar
sorry...guess i didnt read the thread title correctly...i didnt know it was leaking into the car...my leak was just a loose clamp at the firewall in the engine bay. Glad you fixed it though.
Old Oct 6, 2004 | 12:15 PM
slambedcivic's Avatar
Default Re: help me. (94JDMEG)
most likely when you were taking out the old engine or putting the new on in... the rear L bracket caught up on the heater core and broke its lines INSIDE of the car
Old Oct 6, 2004 | 01:26 PM
TallAssFilipino's Avatar
Default Re: help me. (slambedcivic)
Well, he said coolant. So, it's most likely got something to do with his heating system.
Old Oct 6, 2004 | 11:31 PM
New Image's Avatar
Default Re: help me. (TallAssFilipino)
mathews
Oct 4, 2005 02:45 PM
jakeiscool
May 2, 2005 12:25 PM
Spence
Mar 21, 2005 02:19 PM
Hybrid2Be
Oct 20, 2004 06:33 PM
