How much is hp/tq is possible? and is it worth it?
Old Oct 5, 2004 | 10:27 AM
White86CRXSi's Avatar
Default How much is hp/tq is possible? and is it worth it?
well i want a b16 dearly in my si.. but thats a long time away but i was also wondering how much hp is possible to get out this stock motor, is mini-me possible on this motor, its an 86 si stock motor
Old Oct 5, 2004 | 12:57 PM
Waachback's Avatar
I say stick with your stock motor and go with a turbo setup.
Old Oct 6, 2004 | 01:00 PM
Default Re: (Waachback)
any links to where to get a turbo set-up.. how much engine life does this cut off and how hard is this to do?
Old Oct 6, 2004 | 01:12 PM
kurinto's Avatar
Default Re: (White86CRXSi)
Althought I don't regularly read this site, I hear it has the most abundant info on the first gen crx's/ third gen civics: http://www.redpepperracing.com
I'm sure your questions have been asked numerous times there. Good luck.
Old Oct 7, 2004 | 03:40 PM
mar778c's Avatar
Community Builder
Community Influencer
A d16a on 7 to 9 psi is very fast. I think that is about 150 to 170 whp. As long as you stay below 9 psi you should be okay for 80000 to 90000 miles.
Old Oct 7, 2004 | 04:40 PM
EVOLUTIONINNYC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Waachback &raquo;</TD></TR><TR><TD CLASS="quote">I say stick with your stock motor and go with a turbo setup.</TD></TR></TABLE>
hell nah, that would get costly
get a ZC
Old Oct 7, 2004 | 10:58 PM
Waachback's Avatar
It would be cheaper and faster then swapping a B16 in though....that was my point...
Old Oct 8, 2004 | 05:53 PM
underage's Avatar
it is my understanding that a d16 out of a usdm 86-89 integra would bolt in, but you might have to do some wiring.
Old Oct 9, 2004 | 04:34 AM
mar778c's Avatar
Community Builder
Default Re: (underage)
no it won't. The jdn dohc or sohc zc will bolt in. Plus, they are cheap
Old Oct 9, 2004 | 09:27 PM
suicidal2af's Avatar
Default Re: (SiRhatchalot)
Wouldn't be costly at all. Pick up a used 13g out of a 1g auto DSM in good condition, dirt cheap. Nab a DSM SMIC, get all the required lines and hoses, do custom piping. Doing the labor yourself, you could have that motor running 7psi for $300 or so.
Old Oct 9, 2004 | 09:50 PM
mrspeaker's Avatar
Default Re: (suicidal2af)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">no it won't. The jdm dohc or sohc zc will bolt in. Plus, they are cheap</TD></TR></TABLE>
Wrong....ZC motors arent bolt-in to the 84-87 chassis...Ur thinkin about 88-91..
D16s out of 86-89 tegs are bolt-in.....
vtec_killer_
May 19, 2008 02:54 AM
tdark1582
Apr 10, 2007 06:16 AM
saver
Oct 2, 2005 09:16 PM
94integragsr
Jul 27, 2005 08:06 AM
red95integ
Sep 11, 2004 08:53 AM
