Ls Cams the same between 91-93 / 94+?
Just as the topic states.. does anyone know if the LS cams from a 91-93 2nd gen Integra are the same as the 3rd gen 94+ cams?
Thanks,
Ed
edit: would the 2nd gen cams be compatible with a 94+ ls head is actually what I'm getting at.
Thanks,
Ed
well its a big diffrence u see the 90-93 teggy has i think 130-135 hp will the 94 and up has 140-145 hp i have a 91 teggy i put some 99 Ls cams and it ran hard i beat my freind who has the same set up as me he has a stage 4 clutch and a skunk 2 non vtec computer and i still pull on him on 3rd gear by like 2 cars and like i said i have 99 ls cams and also some aem cam gears. so yea 10 to 15 hp increase on 94 and up cams
they are a little different. 90-91 engines are b18a and 94+ are b18b. there is a slight power increase in the 94+ ones. they should be compatible. hope this helps somewhat. oh yeah and the ecus are different. try to use the ecu of the same year to avoid future problems.
