need help !!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 5, 2004 | 09:22 AM
br'Y'an's Avatar
Default need help !!!!!!!!!!!!!!!!!!!!!!!!
i have a 93 accord and it takes a while too start up but it starts up and the check engine lights on.So i wait a minute then turn it off and restart it and most of the time it starts normal and the check engine lights turns off. some people told me that it mite be the fuel pump and that cost $180 because its electronic.i want to know if someone knows whats wrong with it maybe its not the fuel pump thanks
Old Oct 5, 2004 | 09:24 AM
br'Y'an's Avatar
Default Re: need help !!!!!!!!!!!!!!!!!!!!!!!! (beatjunkie42)
and i just bought new sparks,wires, cap and rotor
Old Oct 5, 2004 | 09:33 AM
F22Raptor's Avatar
if its pre OBD all you can do is trial and error. If iits OBD 1 then you can hook it up to the diagnostic computer and see if throws any codes. The codes will tell you why the light is getting turned on. AutoZone does this for free.
Old Oct 6, 2004 | 09:07 AM
br'Y'an's Avatar
Default Re: need help !!!!!!!!!!!!!!!!!!!!!!!! (F22Raptor)
autozone said its free for years 96 and up mines is a 93 so im luck out
Old Oct 6, 2004 | 10:32 AM
luckydog's Avatar
You can pull the codes yourself.
On the passenger side, under the glovebox, against the wall right in front of the door is a small, blue 2-pin connector (mine was still taped to another cable). With the engine off use a paper clip or other suitable device and jumper the 2 positions. Start the car (or turn the key on) and your check engine light will blink. Do a search on "codes: and you'll find out what the blinking means.
And in the future try a more specific title for your post. This is a tech forum- everybody here needs help.
Old Oct 6, 2004 | 11:22 AM
taz104's Avatar
If you buy a book, there's typically a troubleshooting guide in the first section that may help. Haynes or Clymer are the inexpensive ones...$15-25 at Autozone and Kragen.
Good Luck!
Jtadlock78
May 27, 2017 11:05 AM
adam4826
12
Jan 26, 2010 07:05 AM
edm_jdm
Jan 2, 2008 05:45 PM
fuzzy123
Nov 3, 2006 01:31 AM
