are these slicks still good???
Old Oct 5, 2004 | 08:53 AM
peiku's Avatar
Default are these slicks still good???
i kinda tore up my slicks. they look pretty rough. i had them down to about 13-14psi. this happened over a period of about 15 runs. well heres a picture. let me know what you guys think.
Old Oct 5, 2004 | 09:05 AM
DEVIOUS_EG*'s Avatar
Default Re: are these slicks still good??? (peiku)
i would replace them, there almost down to the tread indicators (small holes)
Old Oct 5, 2004 | 09:08 AM
peiku's Avatar
Default Re: are these slicks still good??? (DEVIOUS_EF*)
actually theres still decent amount left. its just dirty. the slicks just spun when i lauched at 5k rpm.
Old Oct 5, 2004 | 10:01 AM
Jokerluv's Avatar
they look to have a few more passes on them
Old Oct 5, 2004 | 10:04 AM
93H22ACX's Avatar
Default Re: (Jokerluv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jokerluv &raquo;</TD></TR><TR><TD CLASS="quote">they look to have a few more passes on them</TD></TR></TABLE>
Old Oct 5, 2004 | 10:47 AM
ninesecrx's Avatar
Default Re: (93H22ACX)
Look fine to me to keep running
Old Oct 5, 2004 | 01:46 PM
hondaguyef's Avatar
Default Re: (ninesecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecrx &raquo;</TD></TR><TR><TD CLASS="quote">Looks fine to me to keep running em' </TD></TR></TABLE>
Old Oct 5, 2004 | 03:25 PM
4piston's Avatar
Default Re: (hondaguyef)
when the ball up like that switch your 2 front tires for the next run
Old Oct 5, 2004 | 03:43 PM
Finest's Avatar
Default Re: (4piston)
Nothing a long burnout can't fix.
Old Oct 5, 2004 | 08:45 PM
MoBoost2JZ's Avatar
Default Re: (Finest)
A small burnout on concrete cleans those up
Old Oct 5, 2004 | 09:41 PM
peiku's Avatar
Default Re: (MoBoost2JZ)
if i did a big burnout, wouldnt chunks fly off??
Old Oct 6, 2004 | 08:39 AM
4piston's Avatar
Default Re: (peiku)
Thats the point. Those ball up like that because you are spinning them down the track. The rubber is rolled 1 way....if you switch the tires on the next pass it will come off on your burnout easily.
Old Oct 6, 2004 | 09:58 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4piston &raquo;</TD></TR><TR><TD CLASS="quote">Thats the point. Those ball up like that because you are spinning them down the track. The rubber is rolled 1 way....if you switch the tires on the next pass it will come off on your burnout easily.</TD></TR></TABLE>
It's not like they're directional tires..
Old Oct 6, 2004 | 11:46 AM
peiku's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">
yeah i figured. i got an import day this saturday. i will try that out.
Old Oct 6, 2004 | 03:49 PM
londa hover's Avatar
Default Re: (peiku)
as lomg as the 5 holes are still visible there fine.
Old Oct 6, 2004 | 09:03 PM
sprayedcrx's Avatar
Default Re: (londa hover)
i think theyll still work great for a few more passes
Old Oct 6, 2004 | 09:40 PM
peiku's Avatar
Default Re: (sprayedcrx)
its just that i have never seen slicks do this before. usually the ones that i see are somewhat smooth.
Old Oct 7, 2004 | 02:47 AM
Ray-mond's Avatar
What are you serious about running those on the track i say no
if you do you might find your self up on the wall as you hear the sirens
going off woundering what the hell happen and you start to remember
OOOooooo **** I should of changed those damn slicks.
Old Oct 7, 2004 | 04:41 AM
Jockobo's Avatar
Default Re: are these slicks still good??? (89hbb16a3)
isnt that normal? my slicks always do that...and they work great!
Old Oct 7, 2004 | 01:23 PM
Default Re: are these slicks still good??? (Jockobo)
my slicks do it too. its from alot of passes with no burn outs. just do a good burn out and it will be smooth again.
Old Oct 7, 2004 | 01:27 PM
SlicksMH's Avatar
Hi peiku; When you see slicks ball up like that two thing come into play here.
#1 Compound is tooooooooo soft and you are spinning.
#2 You are spinning the slicks and you need to go in sizes.
GOOD LUCK peiku.
John@M&H-Hashims
Old Oct 7, 2004 | 10:45 PM
JL's Avatar
JL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89hbb16a3 &raquo;</TD></TR><TR><TD CLASS="quote">What are you serious about running those on the track i say no
OOOooooo **** I should of changed those damn slicks. </TD></TR></TABLE>
right... Trial User nice story.
Old Oct 8, 2004 | 12:53 AM
peiku's Avatar
Default Re: are these slicks still good??? (SlicksMH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlicksMH &raquo;</TD></TR><TR><TD CLASS="quote">Hi peiku; When you see slicks ball up like that two thing come into play here.
GOOD LUCK peiku.
John@M&H-Hashims </TD></TR></TABLE>
thanks for the advice. i was thinking maybe its becus i set the psi too low. i usaully set them at 13-14 psi after the first pass. they wrinkle alittle bit.
i think #2 is the answer. i dump the clutch at 5k and go WOT rightaway. they usually stop spinning in 1st gear. any higher and they will spin all the way to redline.
i will probably upgrade to some 24.5x8x13 but that wont be till later.
Old Oct 8, 2004 | 09:19 AM
onefstek's Avatar
just make sure you give them a good worm up time. do a 2nd gear burnout, that should work for you.
Old Oct 8, 2004 | 04:10 PM
C.R.E.A.M.*562*'s Avatar
still look good 2 me
