d16 swap intake manifold/evac problems
Old Oct 5, 2004 | 07:34 AM
Onoerhime's Avatar
Default d16 swap intake manifold/evac problems
I just replaced a d16 engine on a commuter car, with help from some gear head friends as soon as the car started they bailed on me. I have a hose that is not connected its coming out of the intake manifold on the fire wall side, and when the can is runing it has sucktion, the evac cannister is already connected to a pair of hoses and I have no Idea where this one goes, I don't know **** about cars, my first attempt at self fix, so go easy, thanks in advance if you have suggestions.
Old Oct 5, 2004 | 07:48 AM
snatch's Avatar
Default Re: d16 swap intake manifold/evac problems (Onoerhime)
where is it coming out of the intake manifold at?
is it a D16Y7, Y8, Z6...etc.
Old Oct 5, 2004 | 08:12 AM
Slammd Sol's Avatar
EVAP sensor
Old Oct 5, 2004 | 01:20 PM
Onoerhime's Avatar
Default Re: d16 swap intake manifold/evac problems (******)
it is coming out of the intake manifold on the driver side between the manifold and the firewall kind of towards the bottom of the manifold. I plugged it with something and the car reved aroound 900-1000rpm when I take tohe plug the car revs a little higher.
Old Oct 5, 2004 | 02:25 PM
Slammd Sol's Avatar
Your EVAP sensor is supposed to connect to that vacuum port and another vacuum line goes from that sensor to the evac canister. Check your wiring harness in that area.. I bet theres an unused plug hanging there
Old Oct 5, 2004 | 02:38 PM
Tad's Avatar
Tad
for not knowing **** about cars,
and this being your first attempt at fixing something.
an engine swap is a pretty hefty feat,
pat yourself on the back.
Old Oct 6, 2004 | 09:17 AM
Onoerhime's Avatar
Default Re: (Tad)
thanks every one for the help I got it hooked up it turns out that the whose actually went to a sensor that is connected to my cruise control. the car is running fine know will be done as soon as put in a new thermostat. next up H22 swap, good ish by the way Ricey on that thread on swaps availabe for my civic, I think I'm addicted. once again thanks people
VTECinWOT
Oct 24, 2011 05:27 AM
civicdude00
Aug 4, 2007 09:35 AM
R_type
Jun 1, 2005 04:26 AM
DragInteg
May 4, 2004 09:15 AM
C4wrx
Apr 2, 2002 03:52 AM
