rattleing noise in overdrive
Old Oct 5, 2004 | 07:26 AM
4thGen4dr's Avatar
Default rattleing noise in overdrive
My car has been making this wierd rattling/grinding noise while in overdrive or my 4th gear. The noise lasts 4 seconds after shifting into overdrive and then stops then comes back when I accelerate and stops when i let go, all in overdrive only. It doesnt happen in other gears and Im thinking it could be my distributer for some reason cuz it also sound like its a spinning noise. Also its coming from my passenger side and it happens during 2K to3500k rpm when i accelerate in overdrive . Anyone know what this can be? thanks
Old Oct 5, 2004 | 05:19 PM
KatyHonda's Avatar
Default Re: rattleing noise in overdrive (4thGen4dr)
Catalytic converter heat shield can be a source of noise. The bolts rust and shield gets loose. A stainless steel hose clamp can resecure the shield if thats your problem.
good luck
09pilotdriven
Jun 25, 2018 10:55 AM
wxy117
Mar 24, 2008 10:26 PM
makri
Feb 3, 2006 09:03 AM
jeffb16
Oct 6, 2004 05:00 AM
