what are the largest injectors you can use with an obd2 ecu and vafc?
Old Oct 5, 2004 | 07:13 AM
Black R's Avatar
25 Year Member
Default what are the largest injectors you can use with an obd2 ecu and vafc?
If you go more than -10% on the vafc, does it start to hunt for different timing maps as well? I have heard rumors of this, but would like to understand the reasoning...
Is that good or bad for allmotor/ boost?
The reason I ask is that for one time each year I will need to get emissions done, and will need to use the stock obd2 ecu to do so. I'm trying to think of a way to avoid pulling the injectors and turbo or itb's, etc (I have two different projects).....
Old Oct 5, 2004 | 07:31 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: what are the largest injectors you can use with an obd2 ecu and vafc? (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">If you go more than -10% on the vafc, does it start to hunt for different timing maps as well? I have heard rumors of this, but would like to understand the reasoning...</TD></TR></TABLE>
Uh, I don't think so. I'm running anywhere from - 14-20%
Old Oct 5, 2004 | 07:40 AM
Black R's Avatar
25 Year Member
Default Re: what are the largest injectors you can use with an obd2 ecu and vafc? (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">
Uh, I don't think so. I'm running anywhere from - 14-20%</TD></TR></TABLE>
Ok, then in theory since the vafc can only pull a maximum or -50% the biggest injectors you could run would be 480cc..... (240cc x 2) correct?
I'm just wondering what would happen if I ran 550cc injectors with a vafc for a couple days... idle would suck, but WOT should be ok. Partial throttle should be ok as well... just the idle would eat up some gas, eh...
Old Oct 5, 2004 | 08:01 AM
Banned
You can always adjust fuel pressure to compensate for fuel also.
Old Oct 5, 2004 | 08:57 AM
Black R's Avatar
25 Year Member
Yes, but in this instance I wouldn't feel comfortable turning the fuel pressure down with 550cc's... the spray pattern would suffer and then i would have to deal with other issues (fuel pooling, etc)
Looks like the dsm 450cc injectors are good for something! LOL
itr1244
Jun 15, 2004 01:04 PM
ITR981002
Jun 14, 2004 05:57 PM
Red D Dragon
May 23, 2004 05:42 PM
boost junky 71
May 10, 2004 09:44 AM
B18C_EJ8
Sep 26, 2003 07:28 AM
